EEM policy: Syslog ED & logging Discriminator = Crash
Hi everyone!
I found a new bug in cisco IOS 15.1(4)M3 when running EEM script with syslog event detector.
If system logging performed using the "logging discriminator" and run concurrently EEM script with syslog event detector, then Cisco router crash and goes to reboot.
Cisco ISR G2 3925E.
Joe Clarke
Please post the show ver, show region, and show stack output after the crash.  Also, please include your EEM and logging discriminator config.  Thanks.
Hi Joseph!
SHOW VERSION
i3925E-0-(offline)#sho ver
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9_NPE-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Dec-11 20:22 by prod_rel_team
ass
ROM: System Bootstrap, Version 15.1(1r)T4, RELEASE SOFTWARE (fc1)
i3925E-0-(offline) uptime is 20 hours, 31 minutes
System returned to ROM by bus error at PC 0x14F40AF, address 0x14F40AF at 14:50:19 MSK Thu Mar 15 2012
System restarted at 14:52:14 MSK Thu Mar 15 2012
System image file is "flash0:c3900e-universalk9_npe-mz.SPA.151-4.M3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE200/K9 with 1015808K bytes of memory.
Processor board ID FCZ153920YC
4 Gigabit Ethernet interfaces
DRAM configuration is 72 bits wide with parity enabled.
256K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE200/K9       FOC15357xxx
Technology Package License Information for Module:'c3900e'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9_npePermanent      securityk9_npe
uc            None          None           None
data          None          None           None
SHOW STACK & REGION
i3925E-0-(offline)#show region
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x00000000  0x000FFFFF     1048576  IText  R/W    bios
0x00100000  0x3E0FFFFF  1040187392  Local  R/W    main
0x0010176C  0x04FE31DF    82713204  IText  R/O    main:text
0x04FE3200  0x096E892F    74471216  IData  R/W    main:data
0x096E8930  0x0A2FB1DF    12658864  IBss   R/W    main:bss
0x0A2FB1E0  0x1BFFB1DF   298844160  Iomem  R/W    main:iomem
0x1BFFB1E0  0x3BFFFFFF   536890912  Local  R/W    main:main
0x1BFFB1E0  0x3BFFFFFF   536890912  Local  R/W    main:heap
Free Region Manager:
i3925E-0-(offline)#sho stack
Minimum process stacks:
Free/Size   Name
22876/24000  MRIB IPv6 Init Process
23044/24000  MRIB IPv4 Init Process
10080/12000  EEM Shell Director
42216/60000  EEM TCL Proc
10656/12000  Inspect Init Msg
11036/12000  SPAN Subsystem
39432/48000  Init
58616/60000  EEM Auto Registration Proc
10968/12000  Auto Upgrade Startup Process
10696/12000  DIB error message
11052/12000  SASL MAIN
10884/12000  LICENSE AGENT DEFAULT
10876/12000  RADIUS INITCONFIG
5048/6000   Rom Random Update Process
10996/12000  URPF stats
141636/144000  TCP Command
9552/12000  TFTP Read Process
10944/12000  EM Action CNS
38368/48000  Virtual Exec
Interrupt level stacks:
Level    Called Unused/Size  Name
  1    74177501  16476/18000  Network devices
  2           0  18000/18000  One Shot Timer
  5           3  17872/18000  Console Uart
  7    37018943  17916/18000  Clocktick Interrupt
System was restarted by bus error at PC 0x14F40AF, address 0x14F40AF at 14:50:19 MSK Thu Mar 15 2012
Compiled Tue 06-Dec-11 20:22 by prod_rel_team (current version)
Image text-base: 0x0010176C, data-base: 0x04FE3200
Stack trace from system failure:
FP: 0x1E9B7170, RA: 0x4FDC574
FP: 0x1E9B719C, RA: 0x4FDC527
FP: 0x1E9B71B8, RA: 0x190D227
FP: 0x1E9B7210, RA: 0x190CE69
FP: 0x1E9B7254, RA: 0x190CC2A
FP: 0x1E9B7270, RA: 0x190CBDB
FP: 0x1E9B7288, RA: 0x190E05A
FP: 0x1E9B72BC, RA: 0x285ED30
******* Information of Last System Crash **********
Using flash0:crashinfo_20120315-145019-MSK.
export@cisco.com.
Mar 14 10:32:39.945: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
Mar 14 10:32:39.945: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
Mar 14 10:32:39.945: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
Mar 14 10:32:39.945: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to down
Mar 14 10:32:41.185: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
Mar 14 10:32:41.185: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
Mar 14 10:32:41.185: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
Mar 14 10:32:41.185: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to downCisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE200/K9 with 1015808K bytes of memory.
CMD: 'version 15.1' 10:32:45 UTC Wed Mar 14 2012
CMD: 'service timestamps debug datetime localtime' 10:32:45 UTC Wed Mar 14 2012
CMD: 'service timestamps log datetime localtime' 10:32:45 UTC Wed Mar 14 2012
CMD: PASSWORD statement not printed
CMD: 'hostname i3925E-0-(offline)' 10:32:45 UTC Wed Mar 14 2012
% Hostname contains one or more illegal characters.
Mar 14 10:32:45: %CNS-3-WARNING: CNS ID not changed: bad hostname -Process= "Init", ipl= 0, pid= 3
CMD: 'boot-start-marker' 10:32:45 UTC Wed Mar 14 2012
CMD: 'boot system flash0 c3900e-universalk9_npe-mz.SPA.151-4.M3.bin' 10:32:45 UTC Wed Mar 14 2012
CMD: 'boot-end-marker' 10:32:45 UTC Wed Mar 14 2012
CMD: 'logging discriminator DROP mnemonics drops CFGLOG ' 10:32:45 UTC Wed Mar 14 2012
CMD: 'logging buffered 1024000' 10:32:45 UTC Wed Mar 14 2012
CMD: 'no logging console' 10:32:45 UTC Wed Mar 14 2012
CMD: 'logging monitor discriminator DROP' 10:32:45 UTC Wed Mar 14 2012
CMD: 'no aaa new-model' 10:32:45 UTC Wed Mar 14 2012
CMD: 'clock timezone MSK 4 0' 10:32:45 UTC Wed Mar 14 2012
Mar 14 14:32:45: %SYS-6-CLOCKUPDATE: System clock has been updated from 10:32:45 UTC Wed Mar 14 2012 to 14:32:45 MSK Wed Mar 14 2012, configured from console by console.
CMD: 'no ipv6 cef' 14:32:45 MSK Wed Mar 14 2012
CMD: 'no ip source-route' 14:32:45 MSK Wed Mar 14 2012
CMD: 'ip cef' 14:32:45 MSK Wed Mar 14 2012
CMD: 'no ip domain lookup' 14:32:45 MSK Wed Mar 14 2012
CMD: 'ip name-server 8.8.8.8' 14:32:45 MSK Wed Mar 14 2012
CMD: 'multilink bundle-name authenticated' 14:32:45 MSK Wed Mar 14 2012
CMD: 'crypto pki token default removal timeout 0' 14:32:45 MSK Wed Mar 14 2012
CMD: 'license udi pid C3900-SPE200/K9 sn xxxxxxxxxxxx' 14:32:45 MSK Wed Mar 14 2012
CMD: 'archive' 14:32:45 MSK Wed Mar 14 2012
CMD: ' log config' 14:32:45 MSK Wed Mar 14 2012
CMD: '  logging enable' 14:32:45 MSK Wed Mar 14 2012
CMD: '  notify syslog contenttype plaintext' 14:32:45 MSK Wed Mar 14 2012
CMD: ' path flash:/CFG/config' 14:32:45 MSK Wed Mar 14 2012
CMD: ' write-memory' 14:32:45 MSK Wed Mar 14 2012
CMD: 'redundancy' 14:32:45 MSK Wed Mar 14 2012
CMD: 'ip rcmd remote-host user x.x.x.x user enable' 14:32:45 MSK Wed Mar 14 2012
CMD: 'interface GigabitEthernet0/0' 14:32:45 MSK Wed Mar 14 2012
CMD: ' description if-to-Customers' 14:32:45 MSK Wed Mar 14 2012
CMD: ' bandwidth 1000000' 14:32:45 MSK Wed Mar 14 2012
CMD: ' no ip address' 14:32:45 MSK Wed Mar 14 2012
CMD: ' load-interval 30' 14:32:45 MSK Wed Mar 14 2012
CMD: ' duplex auto' 14:32:45 MSK Wed Mar 14 2012
CMD: ' speed auto' 14:32:45 MSK Wed Mar 14 2012
CMD: ' media-type rj45' 14:32:45 MSK Wed Mar 14 2012
CMD: 'interface GigabitEthernet0/0.98' 14:32:45 MSK Wed Mar 14 2012
CMD: ' encapsulation dot1Q 98' 14:32:45 MSK Wed Mar 14 2012
CMD: ' ip address x.x.x.x 255.255.255.0' 14:32:45 MSK Wed Mar 14 2012
CMD: ' ip nat outside' 14:32:45 MSK Wed Mar 14 2012
CMD: ' no ip virtual-reassembly in' 14:32:46 MSK Wed Mar 14 2012
Mar 14 14:32:46: %IP_VFR-7-FEATURE_DISABLE_IN: VFR(in) is manually disabled through CLI; VFR support for features that have internally enabled, will be made available only when VFR is enabled manually on interface GigabitEthernet0/0.98
CMD: ' arp timeout 180' 14:32:46 MSK Wed Mar 14 2012
CMD: 'interface GigabitEthernet0/1' 14:32:46 MSK Wed Mar 14 2012
CMD: ' bandwidth 1000000' 14:32:46 MSK Wed Mar 14 2012
CMD: ' no ip address' 14:32:46 MSK Wed Mar 14 2012
CMD: ' no ip unreachables' 14:32:46 MSK Wed Mar 14 2012
CMD: ' load-interval 30' 14:32:46 MSK Wed Mar 14 2012
CMD: ' shutdown' 14:32:46 MSK Wed Mar 14 2012
CMD: ' duplex auto' 14:32:46 MSK Wed Mar 14 2012
CMD: ' speed auto' 14:32:46 MSK Wed Mar 14 2012
CMD: ' media-type rj45' 14:32:46 MSK Wed Mar 14 2012
CMD: 'interface GigabitEthernet0/2' 14:32:46 MSK Wed Mar 14 2012
CMD: 'interface GigabitEthernet0/3' 14:32:46 MSK Wed Mar 14 2012
CMD: 'ip forward-protocol nd' 14:32:46 MSK Wed Mar 14 2012
CMD: 'no ip http server' 14:32:46 MSK Wed Mar 14 2012
CMD: 'no ip http secure-server' 14:32:46 MSK Wed Mar 14 2012
CMD: 'ip flow-export version 5' 14:32:46 MSK Wed Mar 14 2012
CMD: 'ip flow-export destination x.x.x.x xxxx 14:32:46 MSK Wed Mar 14 2012
CMD: 'ip flow-top-talkers' 14:32:46 MSK Wed Mar 14 2012
CMD: ' top 50' 14:32:46 MSK Wed Mar 14 2012
CMD: ' sort-by bytes' 14:32:46 MSK Wed Mar 14 201
CMD: 'ip route 0.0.0.0 0.0.0.0 x.x.x.x' 14:32:46 MSK Wed Mar 14 2012
CMD: 'logging source-interface GigabitEthernet0/0.98' 14:32:46 MSK Wed Mar 14 2012
CMD: 'logging host x.x.x.x discriminator DROP' 14:32:46 MSK Wed Mar 14 2012
CMD: 'snmp-server host x.x.x.x public ' 14:32:46 MSK Wed Mar 14 2012
CMD: 'snmp-server manager' 14:32:46 MSK Wed Mar 14 2012
CMD: 'control-plane' 14:32:46 MSK Wed Mar 14 2012
CMD: 'line con 0' 14:32:46 MSK Wed Mar 14 2012
CMD: ' logging synchronous' 14:32:46 MSK Wed Mar 14 2012
CMD: ' login' 14:32:46 MSK Wed Mar 14 2012
CMD: 'line aux 0' 14:32:46 MSK Wed Mar 14 2012
CMD: ' no exec' 14:32:46 MSK Wed Mar 14 2012
CMD: 'line vty 0 5' 14:32:46 MSK Wed Mar 14 2012
CMD: ' exec-timeout 30 0' 14:32:46 MSK Wed Mar 14 2012
CMD: ' transport input all' 14:32:46 MSK Wed Mar 14 2012
CMD: 'scheduler allocate 20000 1000' 14:32:46 MSK Wed Mar 14 2012
CMD: 'ntp server x.x.x.x' 14:32:46 MSK Wed Mar 14 2012
CMD: 'event manager environment _syslog_test Configured' 14:32:46 MSK Wed Mar 14 2012
CMD: 'event manager directory user policy "flash0:/USER/"' 14:32:46 MSK Wed Mar 14 2012
CMD: 'event manager directory user repository flash0:/USER/' 14:32:46 MSK Wed Mar 14 2012
CMD: 'event manager policy Multiple-test.tcl' 14:32:46 MSK Wed Mar 14 2012
Mar 14 14:32:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
CMD: 'end' 14:32:46 MSK Wed Mar 14 2012
Mar 14 14:32:46: %SYS-5-CONFIG_I: Configured from memory by console
SETUP: new interface NVI0 placed in "shutdown" state
Mar 14 14:32:48: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to reset
Mar 14 14:32:48: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
Mar 14 14:32:48: %LINK-5-CHANGED: Interface GigabitEthernet0/2, changed state to administratively down
Mar 14 14:32:49: %LINK-5-CHANGED: Interface NVI0, changed state to administratively down
Mar 14 14:32:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
Mar 14 14:32:50: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to down
Mar 14 14:32:52: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
Mar 14 14:32:55: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
Mar 14 14:32:56: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
Mar 14 14:32:56: %SYS-5-RESTART: System restarted --
Mar 14 14:32:56: %SNMP-5-COLDSTART: SNMP agent on host i3925E-0-(offline) is undergoing a cold start
Mar 14 14:32:58: %SYS-6-BOOTTIME: Time taken to reboot after reload =  121 seconds
Mar 14 14:32:59: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host xx.x..xx port 514 started - CLI initiated
CMD: 'enable' 14:36:05 MSK Thu Mar 15 2012
CMD: 'sho event manager policy registered ' 14:36:12 MSK Thu Mar 15 2012
CMD: 'sho logg' 14:36:26 MSK Thu Mar 15 2012
CMD: 'sho run | inc logg' 14:37:34 MSK Thu Mar 15 2012
CMD: 'sho run | sec DROP' 14:38:35 MSK Thu Mar 15 2012
CMD: 'sho run | sec CFGLOG' 14:39:09 MSK Thu Mar 15 2012
CMD: 'conf t' 14:39:42 MSK Thu Mar 15 2012
CMD: 'no logging discriminator DROP mnemonics drops CFGLOG ' 14:39:45 MSK Thu Mar 15 2012
Mar 15 14:39:45: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty0  logged command:no logging discriminator DROP
CMD: 'conf t' 14:39:51 MSK Thu Mar 15 2012
CMD: 'logging monitor ' 14:40:16 MSK Thu Mar 15 2012
Mar 15 14:40:16: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty0  logged command:logging monitor
CMD: 'do sho logg' 14:40:24 MSK Thu Mar 15 2012
CMD: 'sho logg' 14:40:24 MSK Thu Mar 15 2012
CMD: 'logging buffered ' 14:40:41 MSK Thu Mar 15 2012
Mar 15 14:40:41: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty0  logged command:logging buffered
CMD: 'logg x.x.x.x 14:41:04 MSK Thu Mar 15 2012
Mar 15 14:41:04: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty0  logged command:logging x.x.x.x
CMD: 'do sho logg' 14:41:12 MSK Thu Mar 15 2012
CMD: 'sho logg' 14:41:12 MSK Thu Mar 15 2012
CMD: 'do sho logg | inc DROP' 14:41:44 MSK Thu Mar 15 2012
CMD: 'sho logg | inc DROP' 14:41:44 MSK Thu Mar 15 2012
CMD: 'do sho logg ' 14:41:55 MSK Thu Mar 15 2012
CMD: 'sho logg' 14:41:55 MSK Thu Mar 15 2012
CMD: 'do term mon' 14:42:13 MSK Thu Mar 15 2012
CMD: 'term mon' 14:42:13 MSK Thu Mar 15 2012
CMD: 'exi' 14:42:20 MSK Thu Mar 15 2012
Mar 15 14:42:20: %SYS-5-CONFIG_I: Configured from console by vty0 (x.x.x.x)
Mar 15 14:42:20: %HA_EM-6-LOG: Multiple-test.tcl: START polycy #1...
Mar 15 14:42:20: %HA_EM-6-LOG: Multiple-test.tcl: ENTRY status not exist...
CMD: 'conf t' 14:47:16 MSK Thu Mar 15 2012
Mar 15 14:47:17: %SYS-5-CONFIG_I: Configured from console by vty0 ()
Mar 15 14:47:17: %HA_EM-6-LOG: Multiple-test.tcl: START polycy #1...
Mar 15 14:47:17: %HA_EM-6-LOG: Multiple-test.tcl: ENTRY status not exist...
CMD: 'sho run | inc logg' 14:48:27 MSK Thu Mar 15 2012
CMD: 'conf t' 14:48:40 MSK Thu Mar 15 2012
CMD: 'logging discriminator DROP1 mnemonics drops HA_EM ' 14:48:59 MSK Thu Mar 15 2012
Mar 15 14:48:59: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty0  logged command:logging discriminator DROP1 mnemonics drops HA_EM
CMD: 'logging discriminator DROP1 mnemonics drops LOG ' 14:49:17 MSK Thu Mar 15 2012
Mar 15 14:49:17: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty0  logged command:logging discriminator DROP1 mnemonics drops LOG
Mar 15 14:49:19: %SYS-5-CONFIG_I: Configured from console by vty0 ()
Mar 15 14:49:19: %HA_EM-6-LOG: Multiple-test.tcl: START polycy #1...
Mar 15 14:49:19: %HA_EM-6-LOG: Multiple-test.tcl: ENTRY status not exist...
CMD: 'conf t' 14:49:27 MSK Thu Mar 15 2012
CMD: 'logging monitor discriminator DROP1' 14:50:19 MSK Thu Mar 15 2012
Mar 15 14:50:19: %PARSER-5-CFGLOG_LOGGEDCMD: User:vty0  logged command:logging monitor discriminator DROP1
Mar 15 14:50:19: %SYS-5-CONFIG_I: Configured from console by vty0 ()
14:50:19 MSK Thu Mar 15 2012: Unexpected exception to CPU: vector D, PC = 0x14F40AF
-Traceback= 14F40AF 85A 4FDC574 4FDC527 190D227 190CE69 190CC2A 190CBDB
CPU Register Context:
EAX = 0x1E9B71D4  ECX  = 0x014F408B  EDX = 0x1E9B71D0  EBX  = 0x000000D3
ESP = 0x1E9B70C8  EBP  = 0x1E9B7170  ESI = 0x0000085A  EDI  = 0x00000001
EIP = 0x014F40AF  PS   = 0x00010206  CS  = 0x00000008  SS   = 0x00000010
DS  = 0x00000010  ES   = 0x00000010  FS  = 0x00000010  GS   = 0x00000010
========= Start of Crashinfo Collection (14:50:19 MSK Thu Mar 15 2012) =========
For image:
========= Malloc and Free Traces ===============================================
MallocFree Trace: ixmallocfree=0xD  ptr=0x9DD3C48
9DD3BE0: 1F421B68  4E5DD21 1F4223A0 600003B2 1F6F1E40 4000061C 1F6F1E40  4E4B0D3
9DD3C00: 1F6F1E40  4E4BC70 1F6F2AA8 60000398 1FB0DA8C  15677BC 1FB0E678 600003C6
9DD3C20: 1F1DB08C 40000060 1F1DB08C  153FBB1 1D9E48E4 40000204 1D9E48E4  190D088
9DD3C40: 1F40912C 40000546 1F40912C  190D133 1FB0E678 400002CA 1FB0E678  4E4B0D3
9DD3C60: 1FB0E678  4E6187F 1FB0EC3C 600000E4 1F4223A0 400002CA 1F4223A0  4E4B0D3
9DD3C80: 1F4223A0  4E6187F 1F422964 600000D0 1D9E48E4 400002CA 1D9E48E4  4E4B0D3
9DD3CA0: 1D9E48E4  4E6187F 1D9E4EA8 60000096 1FB0E678 400002CA 1FB0E678  4E4B0D3
9DD3CC0: 1FB0E678  4E6187F 1FB0EC3C 600000E4 1F4223A0 400002CA 1F4223A0  4E4B0D3
9DD3CE0: 1F4223A0  4E6187F 1F422964 600000D0 1D9E48E4 400002CA 1D9E48E4  4E4B0D3
9DD3D00: 1D9E48E4  4E6187F 1D9E4EA8 60000096 1FB0E678 400002CA 1FB0E678  4E4B0D3
9DD3D20: 1FB0E678  4E6187F 1FB0EC3C 600000E4 1F4223A0 400002CA 1F4223A0  4E4B0D3
9DD3D40: 1F4223A0  4E6187F 1F422964 600000D0 1D9E48E4 400002CA 1D9E48E4  4E4B0D3
9DD3D60: 1D9E48E4  4E6187F 1D9E4EA8 60000096 1FB0E678 400002CA 1FB0E678  4E4B0D3
9DD3D80: 1FB0E678  4E6187F 1FB0EC3C 600000E4 1F4223A0 400002CA 1F4223A0  4E4B0D3
9DD3DA0: 1F4223A0  4E6187F 1F422964 600000D0 1D9E48E4 400002CA 1D9E48E4  4E4B0D3
9DD3DC0: 1D9E48E4  4E6187F 1D9E4EA8 60000096 1F1DB834  4E62135 1F1DBE04 600000E2
ChunkMallocFree Trace: ixchunkmallocfree=0x9 ptr=0x9DEF16C
9DEF100:  285CF44  28617F9 1EB10BE4   318BF3   307732 1C18ED7C   318C3F   305775
9DEF120: 1D4F63F0   318C3F   3057C6 1D4F63F0   318C3F   3057C6 1D4F63A0   318BF3
9DEF140:   3058E1 1C18ED7C  285CF44  285B561 1EB10BE4  285CEA5  285B561 1F6982FC
9DEF160:   318BA3   30E02B 1D4F5754  1B16955  1B161B1 1C5644BC  285CF44  28617F9
9DEF180: 1EB10BE4   318BF3   307732 1C18ED7C   318C3F   305775 1D4F63F0   318B53
9DEF1A0:   3118A0 1D4F4804   318B53   3118A0 1D4F4828   318B53   3118A0 1D4F484C
9DEF1C0:   318C3F   3057C6 1D4F63F0   318BF3   3058E1 1C18ED7C  285CF44  285B561
9DEF1E0: 1EB10BE4  285CEA5  285B561 1F6982FC  285CEA5  285B35F 1F6982FC  285CF44
9DEF200:  28617F9 1EB10BE4   318BF3   307732 1C18ED7C   318C3F   305775 1D4F63F0
9DEF220:   318C3F   3057C6 1D4F63F0   318BF3   3058E1 1C18ED7C  285CF44  285B561
9DEF240: 1EB10BE4  285CEA5  285B561 1F6982FC  285CEA5  285B35F 1F6982FC  285CF44
9DEF260:  28617F9 1EB10BE4   318BF3   307732 1C18ED7C   318C3F   305775 1D4F63F0
9DEF280:   318C3F   3057C6 1D4F63F0   318BF3   3058E1 1C18ED7C  285CF44  285B561
9DEF2A0: 1EB10BE4  285CEA5  285B561 1F6982FC  285CEA5  285B35F 1F6982FC  285CF44
9DEF2C0:  28617F9 1EB10BE4   318BF3   307732 1C18ED7C   318C3F   305775 1D4F63F0
9DEF2E0:   318B53   311807 1D4F4804   318B53   311807 1D4F4828   318B53   311807
9DEF300: 1D4F484C   318C3F   3057C6 1D4F63F0   318BF3   3058E1 1C18ED7C  285CF44
9DEF320:  285B561 1EB10BE4  285CEA5  285B561 1F6982FC  285CEA5  285B35F 1F6982FC
9DEF340:  285CF44  28617F9 1EB10BE4   318BF3   307732 1C18ED7C   318C3F   305775
9DEF360: 1D4F63F0   318C3F   3057C6 1D4F63F0   318BF3   3058E1 1C18ED7C  285CF44
9DEF380:  285B561 1EB10BE4  285CEA5  285B561 1F6982FC  285CEA5  285B35F 1F6982FC
9DEF3A0:  285CF44  28617F9 1EB10BE4   318BF3   307732 1C18ED7C   318C3F   305775
9DEF3C0: 1D4F63F0   318C3F   3057C6 1D4F63F0   318BF3   3058E1 1C18ED7C  285CF44
9DEF3E0:  285B561 1EB10BE4  285CEA5  285B561 1F6982FC  285CEA5  285B35F 1F6982FC
========= Stack Trace ==========================================================
========= Context ==============================================================
Signal = 10 Vector = 0xD
========= Stack Dump ===========================================================
Stack Frame Pointer in Context is 0x1E9B70C8, at process level
1E9B6CC8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6CE8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6D08: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6D28: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6D48: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6D68: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6D88: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6DA8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6DC8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6DE8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6E08: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6E28: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6E48: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6E68: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6E88: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6EA8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6EC8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6EE8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6F08: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6F28: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6F48: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6F68: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1E9B6F88: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 1C1F0AC0
1E9B6FA8:      4B0 60381F1C 1C1F0AC0      328 1E63B504      438 4C4BD51D 1E63B504
1E9B6FC8:      ABC 4C4BD51D E46F9B1E 8D9DFC04 1DD54B4C 1E9B6FF8        0 84709B1E
1E9B6FE8: C45A8802 1D88C6B8 1E9B6FF8  288CB4A        0 804E3F1F        0 6D6A2500
1E9B7008: 8A1A0000        0  10000F1        0        0  10000F1  1000000  2000000
1E9B7028:        0        0        0 F80C0000        0 58709B1E  9700520  404AD28
1E9B7048:        0  9700520  404B7E4        0  9700520        3 B0709B1E 335D8402
1E9B7068: 1C1ED564        0        0  9700520        3  404B7E4        1        0
1E9B7088:  CD41E1C 1C1ED40C        0 36010000  6000000 30000000 1E9B716C 8A080000
1E9B70A8: D3000000 1E9B7178 5A080000 70719B1E        0 AF404F01 470E1000  D000000
1E9B70C8: E4709B1E FCF98202  9700520        0 7AF78202 31340000        0 33B5631E
1E9B70E8: C0D15B1E        1 3490401F        0  6000000 73000000  3000000  1000000
1E9B7108: 1E9B70DC  4000000  1000000        0        0 1E9B70F0        0 5A080000
1E9B7128:      85A 1F409357        1 7C080000 1E9B7134 1E9B7180 87070000 5A080000
1E9B7148: FFFFFFFF        0        0 D3000000        0 20000000        0 FFFFFFFF
1E9B7168: FFFFFFFF 1E9B7178 9C719B1E 74C5FD04 1F40942A FFFFFFFF  54BED16 D4719B1E
1E9B7188:        0      85A 986FF51E 7454F51E  9C62CC0 B8719B1E 27C5FD04 1F409357
1E9B71A8:      85A  54BEC40 CC719B1E CC719B1E 10729B1E 27D29001 1F409357      85A
1E9B71C8:  54BEC40        4        1 1D9E48E4 1F4091F1      9C0       29        1
1E9B71E8:        0        3  9C64024  9C62CC0 7454F51E  9C62CFC 1D9E48E4 7454F51E
1E9B7208: 78AEA71E 986FF51E 54729B1E 69CE9001  C737F1E 64E6EC1D        1   1572B8
1E9B7228:        1        0  9C62CC0 78AEA71E 1EA7AE78  9C62CC0  A000000   150000
1E9B7248: C02CC609        0 15000000 70729B1E 2ACC9001 D9BE8502 1DECE6C4 1E9B72B8
1E9B7268:  9C62CC0  A000000 88729B1E DBCB9001 1E9B72B0 90729B1E 1E9B72B0  9C62CC0
1E9B7288: BC729B1E 5AE09001  9C62CC0 1DECE664        0        1        0        0
1E9B72A8:        0        0        2 1E865DD0        2        0 30ED8502        0
1E9B72C8: FD0110DF AB1234CD FFFE0000        0  515505C  18DA0DD 1E9B732C 1E9B342C
1E9B72E8: 80000018        1        0  1000001 1C1F0F70 1E7FD4FC 1E7FD460  6ADF740
1E9B7308:        C  4000000        0     1D22 FFFFFFFF FFFFFFFF FFFFFFFF        0
1E9B7328: FD0110DF AB1234CD FFFE0000        0  515505C  18DA0DD 1E9B738C 1E9B72E0
1E9B7348: 80000018        1        0  1000001 1C1F0F70 1E3CD1D8 1E7FD4B0  6AE25A0
1E9B7368:        E  4000000        0     204F FFFFFFFF FFFFFFFF FFFFFFFF        0
1E9B7388: FD0110DF AB1234CD FFFE0000        0  515505C  18DA101 1E9B73D8 1E9B7340
1E9B73A8: 8000000E        1        0  1000001 1C1F0F70 746D5F66 7379735F 75736167
1E9B73C8: 652E7463 6C000000        0 FD0110DF AB1234CD FFFE0000        0  515505C
1E9B73E8:  18DA0DD 1E9B7438 1E9B73A0 80000018        1        0  1000001 1C1F0F70
1E9B7408: 1E7FD5A8 1E7FD55C        0       11  6000000        0        0 FFFFFFFF
1E9B7428: FFFFFFFF FFFFFFFF        0 FD0110DF AB1234CD FFFE0000        0  515505C
1E9B7448:  18DA101 1E9B7484 1E9B73EC 8000000E        1        0  1000001 1C1F0F70
1E9B7468: 65656D5F 706E745F 30000000        0        0        0 FD0110DF AB1234CD
1E9B7488: FFFE0000        0  515505C  18DA0DD 1E9B74E4 1E9B744C 80000018        1
1E9B74A8:        0  1000001 1C1F0F70 1E9B78BC 1E7FD608        0       14  6000000
========= Process Level Info ===================================================
---- Current Process Stack (0x324 bytes used, out of 0x3E80 available) ----
Current SP = 0x1E9B70C8, saved SP = 0x1C1D2628
1E9B6FA4: 1C1F0AC0      4B0 60381F1C 1C1F0AC0      328 1E63B504      438 4C4BD51D
1E9B6FC4: 1E63B504      ABC 4C4BD51D E46F9B1E 8D9DFC04 1DD54B4C 1E9B6FF8        0
1E9B6FE4: 84709B1E C45A8802 1D88C6B8 1E9B6FF8  288CB4A        0 804E3F1F        0
1E9B7004: 6D6A2500 8A1A0000        0  10000F1        0        0  10000F1  1000000
1E9B7024:  2000000        0        0        0 F80C0000        0 58709B1E  9700520
1E9B7044:  404AD28        0  9700520  404B7E4        0  9700520        3 B0709B1E
1E9B7064: 335D8402 1C1ED564        0        0  9700520        3  404B7E4        1
1E9B7084:        0  CD41E1C 1C1ED40C        0 36010000  6000000 30000000 1E9B716C
1E9B70A4: 8A080000 D3000000 1E9B7178 5A080000 70719B1E        0 AF404F01 470E1000
1E9B70C4:  D000000 E4709B1E FCF98202  9700520        0 7AF78202 31340000        0
1E9B70E4: 33B5631E C0D15B1E        1 3490401F        0  6000000 73000000  3000000
1E9B7104:  1000000 1E9B70DC  4000000  1000000        0        0 1E9B70F0        0
1E9B7124: 5A080000      85A 1F409357        1 7C080000 1E9B7134 1E9B7180 87070000
1E9B7144: 5A080000 FFFFFFFF        0        0 D3000000        0 20000000        0
1E9B7164: FFFFFFFF FFFFFFFF 1E9B7178 9C719B1E 74C5FD04 1F40942A FFFFFFFF  54BED16
1E9B7184: D4719B1E        0      85A 986FF51E 7454F51E  9C62CC0 B8719B1E 27C5FD04
1E9B71A4: 1F409357      85A  54BEC40 CC719B1E CC719B1E 10729B1E 27D29001 1F409357
1E9B71C4:      85A  54BEC40        4        1 1D9E48E4 1F4091F1      9C0       29
1E9B71E4:        1        0        3  9C64024  9C62CC0 7454F51E  9C62CFC 1D9E48E4
1E9B7204: 7454F51E 78AEA71E 986FF51E 54729B1E 69CE9001  C737F1E 64E6EC1D        1
1E9B7224:   1572B8        1        0  9C62CC0 78AEA71E 1EA7AE78  9C62CC0  A000000
1E9B7244:   150000 C02CC609        0 15000000 70729B1E 2ACC9001 D9BE8502 1DECE6C4
1E9B7264: 1E9B72B8  9C62CC0  A000000 88729B1E DBCB9001 1E9B72B0 90729B1E 1E9B72B0
1E9B7284:  9C62CC0 BC729B1E 5AE09001  9C62CC0 1DECE664        0        1        0
1E9B72A4:        0        0        0        2 1E865DD0        2        0 30ED8502
1E9B72C4:        0
========= Interrupt Level Stack Dump ===========================================
========= Interrupt Stack ======================================================
---- Level 1 Interrupt stack (0x618 bytes used, out of 0x4650 available) ----
intstacks[1]: base 0x1D48ED84 stack 0x1D4933D0 routine 0x1F41F6
              size 0x4650     low   0x4650     desc    Network devices
1D492DBC: E02D491D E02D491D E82D491D E82D491D B7222000  7000000  8000000 78000000
1D492DDC: 1CA7DAA0 C0000000  1000000 302E491D 102E491D 102E491D B7222000  7000000
1D492DFC: 28000000 28000000        0 C0000000  1000000 682E491D 521E2000 882E491D
1D492E1C: 582F491D        0 582F491D 782E491D 938FDB01 802E491D 938FDB01 5C2E491D
1D492E3C:        1        0        0 882E491D  42F491D 1D492E88  42F491D FC31491D
1D492E5C:  A0103FB 1CA7DAA0 A0DAA71C        0        0        0  A0103FB 802F491D
1D492E7C: 778BDD01 1CA7DAA0  A0103FB 1D492F58        0        0        0        1
1D492E9C:        1        0        0        0        0 40010000 1D492F04        0
1D492EBC:  42F491D E02E491D 15B2DD01 E030491D  9CD4EEC 282F491D 982F491D 7431491D
1D492EDC: 1CA7DAA0 FC2E491D 1D44DD01 1D492F04 7431491D 982F491D 1CA7DAA0  B12D612
1D492EFC: E831491D E5722E00 1CA7DAA0  B12D612  B12D626        0        0        0
1D492F1C:  A0002FB FFFFFFFF        0        0        0       17    60000        0
1D492F3C:        0        0        0        0 1C1F0E44 70461F1C 682F491D 8D9DFC04
1D492F5C: 1C1F4670 1D492F7C E065351C  830491D C45A8802 1D88C598 1D492F7C  288CB4A
1D492F7C: 8A7A2E00  6000000        0 1CA7DAA0        6 FFFFFFFE 1CA7DAA0 FFFFFFFE
1D492F9C:        0  1000004 8D9DFC04 1C1F4670 1D492FC8 6014341C 5430491D 1CA7DAA0
1D492FBC: 1D88C598 1CA7DAA0  288CB4A EC2F491D EC2F491D B7222000  7000000 1D5C9D44
1D492FDC: 1430491D 37478502        6 1030491D AD324C00        0  6000000 F027981D
1D492FFC: 1D982800 1D9827F0  2020000 C7188502      206 1D9826A0 1D98279C  97B785C
1D49301C: 3830491D 446B9000  97B785C 1D98279C        2 A026981D        1 6030491D
1D49303C: 57958502        1 46020000 88929000      206        0 5C30491D  8929000
1D49305C: 8C30491D 2B938502        1 8430491D 8430491D 21EB8402  1000000 1C179EC8
1D49307C: C89E171C 1C3565E0        6 A026981D A030491D D3C18502        0 1C3565E0
1D49309C: 1C3565E0 BC30491D 4BFC4A00 1C179EC8 C430491D ED24BB01 1C179EC8 FB02000A
1D4930BC: FB02000A        6 D030491D 8F52B701 5862340A 2031491D 9E49B701 1C3565E0
1D4930DC: 57F85000 1CA7DAA0  B12D612 2418541C 1CA7DAA0 E065351C  9195000  1040000
1D4930FC:  A0002FB  56142C4 767CCA09        6 1D60B6C0 3031491D E065351C        7
1D49311C: 1C3565E0 3431491D CAB98602 1C3565E0  A34624A 1C3565E0 A831491D 12488B02
1D49313C:        7 1C3565E0        0        0        0        1        0 1D4931B0
1D49315C:        0        1        0 757CCA09        1 8061631E E065351C A0DAA71C
1D49317C:        0 4A62340A    80000        4        1 E065351C E065351C 1D60B6C0
1D49319C: E065351C  A34624A 1C541824 C831491D 62378B02 94E38402  6D31268        0
1D4931BC: 1C3565E0       63 E065351C DC31491D CAB98602 1C3565E0       63 1C3565E0
1D4931DC:  C32491D 91504900       63 A0DAA71C  9000000        9  C32491D 34A38202
1D4931FC: 1E1000DC 1E107EAC  28AA52D  28AA52D 3432491D 2DA58A02 1E1000DC 1E107EAC
1D49321C:        1        0 1E107EAC 1CA7DAA0  9000000 A0DAA71C 8832491D 25121F00
1D49323C:        9 1CA7DAA0 12000000   D6120B A0DAA71C 1C3565E0 A0DAA71C E04E4900
1D49325C: 1D630C4C 1D653C00   D6120B 1CA7DAA0 4662340A 1D60B6C0 A0DAA71C    10000
1D49327C:   2834FA 1D60B6C0 18DBA71C A032491D 11251F00  6A86E44 A0DAA71C    10000
1D49329C:  B12D60C  C33491D 627A2800 1D60B6C0 1CA7DAA0   2834FA  B12D60C 8C5A8802
1D4932BC:  7000000        0 C0B6601D A0DAA71C 7EAF8802 38D4601D        0 F832491D
1D4932DC:  B12D600   620000 1D60B6C0 1C541824 1C541824        0 1CA7DAA0 1D60C348
1D4932FC: A0DAA71C 60CACB0A 1D60B6C0 F8A0D306 8833491D 519E2800 8833491D 5C33491D
1D49331C: 5C33491D 5AD94700 1D60B6C0 38D4601D 60E90106  5D6FE9C      600 6033491D
1D49333C: 57958502 18DBA71C 1CA7DAA0        0 1CA7DAA0 1D60D438 F8050000 F0CFCB0A
1D49335C: 38D4601D 60CACB0A        0 C0B6601D C0B6601D 1D60B6C0 B4E8621D 1D662380
1D49337C:        0       20 1CA7DAA0 AC33491D 1AA62800 1D60B6C0        0        0
1D49339C:        1 1D60B6C0 1D60B6C0 80060000 C433491D 73A62800 C433491D 85A82500
1D4933BC: 80060000 14983206 8C709B1E 1E212000 1D60B6C0 FFFFFFFF
---- Level 2 Interrupt stack (0x0 bytes used, out of 0x4650 available) ----
intstacks[2]: base 0x1D48A734 stack 0x1D48ED80 routine 0x25650A
              size 0x4650     low   0x4650     desc    One Shot Timer
---- Level 5 Interrupt stack (0x80 bytes used, out of 0x4650 available) ----
intstacks[5]: base 0x1D4860E4 stack 0x1D48A730 routine 0x20C4F6
              size 0x4650     low   0x4650     desc    Console Uart
1D48A6B4: C4A6481D 17BF2000  3F90000  D000000 DCA6481D E1BA2000 FFFFFFFF E0A6481D
1D48A6D4: 17BF2000 1C17676F  8A7481D 24C42000 1C174618 FFFFFFFF FFFFFFFF FFFFFFFF
1D48A6F4: 1C174618        0  8A7481D CCBE2000  2FA0000 28A7481D 6CC52000 FFFFFFFF
1D48A714: FFFFFFFF FFFFFFFF 30A7481D F6C42000  4983206 B0E3781D C6222000 FFFFFFFF
---- Level 7 Interrupt stack (0x54 bytes used, out of 0x4650 available) ----
intstacks[7]: base 0x1D481A94 stack 0x1D4860E0 routine 0x91D8F0
              size 0x4650     low   0x4650     desc    Clocktick Interrupt
1D486090:        0  536CFF2        0  536CFF6 1D78E474 46020000 D22B8502      202
1D4860B0: EDBF9000 FFFFFFFF C860481D 6B872200 D060481D 67938202 D060481D 25DA9100
1D4860D0: D860481D BFD99100 20261D1C C6222000 FFFFFFFF
========= Register Memory Dump =================================================
Reg00(EAX): 1E9B71D4
Reg01(EBX):       D3
Reg02(ECX):  14F408B
Reg03(EDX): 1E9B71D0
Reg04(ESP): 1E9B70C8
Reg05(EBP): 1E9B7170
Reg06(ESI):      85A
Reg07(EDI):        1
Reg08(EIP):  14F40AF
Reg09(PS ):    10206
Reg10(CS ):        8
Reg11(SS ):       10
Reg12(DS ):       10
Reg13(ES ):       10
Reg14(FS ):       10
Reg15(GS ):       10
buffer check=0 sched_hc=0x0
---- block0  ptr=1E9B7068  is_malloc=0  length=0x260 ----
---- block1  ptr=1C1ED488  is_malloc=1  length=0x1AC ----
1C1ED448:        0        0 1C1ED4FC 1C1ED4C0 1C1ED448  6D31580       69    D0000
1C1ED468:        0        0  5781DD4  2851E0A  2851E14  6D31568        0 FD0110DF
1C1ED488: AB1234CD FFFE0000        0  515505C  2846FA7 1C1ED534 1C1ED3F0 8000003E
1C1ED4A8:        1        0  1000001 1C1F0F70        0        0 1C1ED450 1C1ED414
1C1ED4C8: 1C1ED4B8  6D31580       68    D0000        0        0  5781DE8  2851E0A
1C1ED4E8:  2851E14  6D31568        0        0        0 1C1EC668 1C1ED450 1C1ED4F4
1C1ED508:  6D31580       6A    D0000        0        0  5781DE8  2851E0A  2851E14
1C1ED528:  6D31568        0 FD0110DF AB1234CD FFFE0000        0  515505C  2847042
1C1ED548: 1C1ED610 1C1ED49C 80000056        1        0  1000001 1C1F0F70        0
1C1ED568:        0        0        0        0        0        0        0        0
1C1ED588:        0        0        0        0        0        0        0        0
1C1ED5A8:        0        0        0        0        0        0        0        0
1C1ED5C8:        0        0        0        0        0        0        0        0
1C1ED5E8:        0        0        0        0        0        0        0        0
1C1ED608:        0 FD0110DF AB1234CD FFFE0000        0  5781DC0  28470FE 1C1ED6B8
1C1ED628: 1C1ED548 8000003C        1
---- block2  ptr=9700520  is_malloc=0  length=0x100 ----
97004E0: FFA42200 46020000  8000000 10000000 10000000 10000000 10000000 10000000
9700500:        0   22735A        0        1        0        0        0        0
9700520:  5010EDC        1  6005190  6005190  97B9A6C  97014F8  9700528  6D31580
9700540:        7    10000        1        0  5010EDC  2851E0A  2851E14  6D31568
9700560:        0  DFDCB1E   570000  DF04B36 1FEB7948 20004E20        0       EF
9700580:   5C6802        0        0 1BFFB1E0        0        0    18000     8000
97005A0:        0        0        0        0        0        0        0        0
97005C0:  9700950  9700C98       1E        E        0        E        0       27
97005E0: 1E7C2A28        0        0        0        0        0 1F1DB18C        0
9700600:        0        0       28        F       28       28       33  9700620
---- block3  ptr=CD41E1C  is_malloc=0  length=0x100 ----
CD41DDC:      D9B        0      D9B        0      D9B        0      D9B        0
CD41DFC:      D9B        0      E1C        0      E1C        0      E1C        0
CD41E1C:      E1C        0      E1C        0      E1C        0      E1C        0
CD41E3C:      E1C        0      E1C        0      E1C        0      E1C        0
CD41E5C:      E1C        0      E1C        0      E1C        0      E1C        0
CD41E7C:      E1C        0      E9D        0      E9D        0      E9D        0
CD41E9C:      E9D        0      E9D        0      E9D        0      E9D        0
CD41EBC:      E9D        0      E9D        0      E9D        0      E9D        0
CD41EDC:      E9D        0      E9D        0      E9D        0      E9D        0
CD41EFC:      E9D        0      F1E        0      F1E        0      F1E        0
---- block4  ptr=1C1ED38C  is_malloc=1  length=0x150 ----
1C1ED34C:      100 1C1ECDAC        0 1C1ED8D8 1C1EC624      100 1C1ECDAC        0
1C1ED36C: 1C1ED3C4 1C1EC754      100        0        0        0        0 FD0110DF
1C1ED38C: AB1234CD FFFE0000        0  53D85F8  28866DC 1C1ED3DC 1C1ECD90 80000010
1C1ED3AC:        1        0  1000001 1C1F0F70 6D656D6F 72790000        0 5BAF9596
1C1ED3CC: 1C1ED368        0  6000008 FD0110DF AB1234CD FFFE0000        0  515505C
1C1ED3EC:  2846F91 1C1ED488 1C1ED3A0 8000003E        1        0  1000001 1C1F0F70
1C1ED40C:        0        0 1C1ED4C0 1C1EC81C 1C1ED40C  6D31580       67    D0000
1C1ED42C:        0        0  5781DD4  2851E0A  2851E14  6D31568        0        0
1C1ED44C:        0 1C1ED4FC 1C1ED4C0 1C1ED448  6D31580       69    D0000        0
1C1ED46C:        0  5781DD4  2851E0A  2851E14  6D31568        0 FD0110DF AB1234CD
1C1ED48C: FFFE0000        0  515505C  2846FA7 1C1ED534 1C1ED3F0 8000003E        1
1C1ED4AC:        0  1000001 1C1F0F70        0        0 1C1ED450 1C1ED414 1C1ED4B8
1C1ED4CC:  6D31580       68    D0000        0
---- block5  ptr=36010000  is_malloc=0  length=0x100 ----
3600FFC0:        0        0        0        0        0        0        0        0
3600FFE0:        0        0        0        0        0        0        0        0
36010000:        0        0        0        0        0        0        0        0
36010020:        0        0        0        0        0        0        0        0
36010040:        0        0        0        0        0        0        0        0
36010060:        0        0        0        0        0        0        0        0
36010080:        0        0        0        0        0        0        0        0
360100A0:        0        0        0        0        0        0        0        0
360100C0:        0        0        0        0        0        0        0        0
360100E0:        0        0        0        0        0        0        0        0
---- block6  ptr=6000000  is_malloc=0  length=0x100 ----
5FFFFC0: 3CF63C89 E4AA954C E121426E 52D198F9 4106CC9E 889F1365 E75A7785 3FA3E8A8
5FFFFE0: AFE382E1 35B3B2F7 86F711F7 723E31F2 62DAB426 9B1B499E 35932DAC 239EE27E
6000000: B386527C E8CAC680 6AA06340 8E041CEC   E51836 FBA90814 5FFF6A22 2B469481
6000020: 542CB93A 262EFF02 ED38D3D2 9933F6EB 8D9E84C6 C79AE572 700CCB69 2097F464
6000040: 63C0AD83 503D7B00 70E1CF9B 62FA2E30 5E5E7771 E5D9EE14 B8C56714 2011CE7A
6000060: 7E5DC339 5BB9732E 1223BFA3 5844B5CD 3AA38B2D 3117E51D 35D53CF2 26759487
6000080: 18AABB89 9C800C78 4548DD96 E6A8833D 12C4CC64 E4567430 596306BD E3B3C21A
60000A0: F94FD83B B4F04005 2550E677 31529D9C  5EE83FD A5DAFEB2 568B58CB 380F2902
60000C0: 8468D893 CDBC40FE  EFD658A ED416E94 25041C27 A1FDEC4C A92E2AC9 4AA45A37
60000E0: BBA463B1 64B8D1C2 B17727E1 54998746 9E2FD10F 4ACD721B C15B0F10 8F877B0A
---- block7  ptr=30000000  is_malloc=0  length=0x100 ----
2FFFFFC0: 2AB01448  6E60026 40078400 938031C0 506000D0 1B7812E8  4B4049A  20D80DB
2FFFFFE0: 250E540D 9C074E01 154029B0  BC0E720 EA10B42F E065A00F D01EE0BE 1E20E78D
30000000: 8909C373 E4F136FE E08FDBFE FE228CC7 8070E025 A0C3459A 1EFFF8BA 3D5C84BA
30000020: 78402EEC BFA59B88 7F2A9F7F AAEC5CFD 756E5D84 AEB72A42 C5C04AA0 3F70A465
30000040: 119A0F84  2169306 46D00693 65A0458B 2FA65A9D 596BE88E A7C07627 EFF13CE9
30000060: 1DF7338E 2C429381 11402FA0 15E033B2 48D03FCE 64F0859B 4930EA4C E40194CB
30000080: CF44E62D BBF6CD4C 2CF476C2 7826F014 EC33B171 9010EFFD 293F4C6B 3085CD30
300000A0: 19E2F023 82B03013 67C70B3A 18F24930  C01268C 1B218863 81AE5AEC 87B7C47E
300000C0: 78F6A946 4B2DC0F1 FDA33509 D81C5CBC C6841F9A B9FC67E9 346EB2C4 CF64D224
300000E0: F2D3151D 1F8CA869 349E5F9C 4937C3A2  917F891 2F379CC7 C89685BD 7AD0AFA6
---- block8  ptr=D000000  is_malloc=0  length=0x100 ----
CFFFFC0:        0        0        0        0        0        0        0        0
CFFFFE0:        0        0        0        0        0        0        0        0
D000000:        0        0        0        0        0        0        0        0
D000020:        0        0        0        0        0        0        0        0
D000040:        0        0        0        0        0        0        0        0
D000060:        0        0        0        0        0        0        0        0
D000080:        0        0        0        0        0        0        0        0
D0000A0:        0        0        0        0        0        0        0        0
D0000C0:        0        0        0        0        0        0        0        0
D0000E0:        0        0        0        0        0        0        0        0
---- block9  ptr=31340000  is_malloc=0  length=0x100 ----
3133FFC0:        0        0        0        0        0        0        0        0
3133FFE0:        0        0        0        0        0        0        0        0
31340000:        0        0        0        0        0        0        0        0
31340020:        0        0        0        0        0        0        0        0
31340040:        0        0        0        0        0        0        0        0
31340060:        0        0        0        0        0        0        0        0
31340080:        0        0        0        0        0        0        0        0
313400A0:        0        0        0        0        0        0        0        0
313400C0:        0        0        0        0        0        0        0        0
313400E0:        0        0        0        0        0        0        0        0
---- block10  ptr=33B5631C  is_malloc=0  length=0x100 ----
33B562DC:        0        0        0        0        0        0        0        0
33B562FC:        0        0        0        0        0        0        0        0
33B5631C:        0        0        0        0        0        0        0        0
33B5633C:        0        0        0        0        0        0        0        0
33B5635C:        0        0        0        0        0        0        0        0
33B5637C:        0        0        0        0        0        0        0        0
33B5639C:        0        0        0        0        0        0        0        0
33B563BC:        0        0        0        0        0        0        0        0
33B563DC:        0        0        0        0        0        0        0        0
33B563FC:        0        0        0        0        0        0        0        0
---- block11  ptr=3490401C  is_malloc=0  length=0x100 ----
34903FDC:        0        0        0        0        0        0        0        0
34903FFC:        0        0        0        0        0        0        0        0
3490401C:        0        0        0        0        0        0        0        0
3490403C:        0        0        0        0        0        0        0        0
3490405C:        0        0        0        0        0        0        0        0
3490407C:        0        0        0        0        0        0        0        0
3490409C:        0        0        0        0        0        0        0        0
349040BC:        0        0        0        0        0        0        0        0
349040DC:        0        0        0        0        0        0        0        0
349040FC:        0        0        0        0        0        0        0        0
---- block12  ptr=515505C  is_malloc=0  length=0x100 ----
515501C: 6E202564 20737461 7475733D 4558545F 4E45575F 564C414E        0  A446561
515503C: 6C6C6F63 61746520 65787420 766C616E 20256400 45787420 566C616E 20444220
515505C: 496E6974        0 6578745F 766C616E 5F676574 5F766C61 6E5F696E 666F0000
515507C: 564C414E 25303475        0        0        0        0        0        0
515509C:        0  A767470 5F676574 5F747275 6E6B5F69 6E666F20 6174746D 65707465
51550BC: 64206F6E 20747275 6E6B2030 7825782C 206E6F74 20666F75 6E642069 6E207472
51550DC: 756E6B20 6C697374        0        0        0        0        0        0
51550FC:        0  A767470 5F766C61 6E5F6368 616E6765 5F6E6F74 69666963 6174696F
515511C: 6E3A204D 4F444946 49454420 564C414E 20282564 2920444F 45534E27 54204558
515513C: 49535421 21210000        0        0        0        0        0        0
---- block13  ptr=1C1F0F70  is_malloc=0  length=0x100 ----
1C1F0F30: 1C1F0F0C 1C1EE5E0        0        0        0        0        0        0
1C1F0F50:        0        0        0        0 15A3C78B        1  288C988 1C1EE8B8
1C1F0F70:        0  1000001 1C1F25ED      301  2861A94        0  1000000        0
1C1F0F90: 1C1F0F28 1C1F0F70 1C1EE5E0        0        0        0        0        0
1C1F0FB0:        0        0        0        0        0        0 FD0110DF AB1234CD
1C1F0FD0: FFFE0000        0 1C1E4848  288BDA8 1C1F2000 1C1EE89C 80000802        1
1C1F0FF0:        0  1000001 1C1F0F70 1C1F0F70 80000000 1C1F0F0C 80000000 1C1F0EA8
1C1F1010: 80000000 1C1F0E44 80000000 1C1F0DE0 80000000 1C1F0D7C 80000000 1C1F0D18
1C1F1030: 80000000 1C1F0CB4 80000000 1C1F196C     8000 1C1F0BEC 80000000 1C1F0B88
1C1F1050: 80000000 1C1F0B24 80000000 1C1F0AC0 80000000 1C1F0A5C 80000000 1C1F09F8
---- block14  ptr=5781DC0  is_malloc=0  length=0x100 ----
5781D80: 30782578 7A200000 25733A25 787A2000  A257320 5741564C 20496E69 74204661
5781DA0: 696C6564        0  A257320 4D6E616D 6520496E 69742046 61696C65 64000000
5781DC0: 4D656D6F 72792047 54452063 68756E6B        0 476C6F62 616C2054 68726573
5781DE0: 68204C69 73740000 476C6F62 616C204E 6F746966 69636174 696F6E20 4C697374
5781E00:        0 6D67645F 74696D65 72000000 63686563 6B5F7469 6D657200 6D67645F
5781E20: 74696D65 725F6669 7273745F 65787069 72656400  A627020 28257029 206E6F74
5781E40: 20696E20 6D656D70 6F6F6C28 25702900  A627028 25702920 6E6F7420 696E2061
5781E60: 6E79206D 656D706F 6F6C0000 436F7272 75707465 64207265 647A6F6E 65200000
5781E80: 436F7272 75707465 64207072 6576696F 75732070 6F696E74 65722000 436F7272
5781EA0: 75707465 64206E65 78742070 6F696E74 65722000 496E7661 6C696420 626C6F63
---- block15  ptr=1C1ED610  is_malloc=1  length=0x1A8 ----
1C1ED5D0:        0        0        0        0        0        0        0        0
1C1ED5F0:        0        0        0        0        0        0        0 FD0110DF
1C1ED610: AB1234CD FFFE0000        0  5781DC0  28470FE 1C1ED6B8 1C1ED548 8000003C
1C1ED630:        1  282AD1C  1000001 1C1F0F70 1C1ED6E8        0        0        0
1C1ED650:        0       40        0       30       34        0        0        0
1C1ED670:        0        0       41  9700520        0        0        0        0
1C1ED690: 4D656D6F 72792047 54452063 68756E00 1C1ED6B4 1C1ED6B4        0        0
1C1ED6B0:        0 FD0110DF AB1234CD FFFE0000        0  5160BD4   90EF68 1C1ED760
1C1ED6D0: 1C1ED624 8000003C        1  282AD1C  1000001 1C1F0F70 1C1ED9BC 1E6E323C
1C1ED6F0:        0        0 1C2061C4      400        0      110      120        0
1C1ED710:      121      128       9F        0       21  9700520        0        0
1C1ED730:        0        0 43505520 524F2052 55204368 756E6B00 1C1ED75C 1C1ED75C
1C1ED750:        0        0        2 FD0110DF AB1234CD FFFE0000        0  515505C
1C1ED770:  2885DF2 1C1ED858 1C1ED6CC 80000064        1        0  1000001 1C1F0F70
1C1ED790: 746F7461 6C000000        0        0        0        0        0        0
1C1ED7B0:        0        0
---- block16  ptr=5160BD4  is_malloc=0  length=0x100 ----
5160B94: 72205374 61636B00  A435055 5F524F3A 204E756C 6C20636F 6E746578 74200000
5160BB4:  A435055 20524F3A 20435055 20524F20 63726561 74696F6E 20457272 6F720000
5160BD4: 43505520 524F2052 55204368 756E6B73        0 43505520 524F2055 73657273
5160BF4:        0 50657263 656E7400 6D696E6F 72000000 6D616A6F 72000000 61626F72
5160C14: 74206174 20504320 25236C78        0 62726561 6B206174 20504320 25236C78
5160C34:        0 65786974 20747261 70206174 20504320 25236C78        0 74726163
5160C54: 65207472 61702061 74205043 2025236C 78000000 656D7420 61742050 43202523
5160C74: 6C780000 77617463 68646F67 2074696D 65722065 78706972 65640000 6572726F
5160C94: 72202D20        0 2C205043 2025236C 78000000 72656475 6E64616E 63792072
5160CB4: 65736574        0  A4F6273 6F6C6574 6520524F 4D20736F 66747761 72650000
---- block17  ptr=5010EDC  is_malloc=0  length=0x100 ----
5010E9C:  A466169 6C642074 6F206372 65617465 204D4149 4E312072 6567696F 6E0A0000
5010EBC:  A466169 6C656420 746F2063 72656174 65204845 41502072 6567696F 6E0A0000
5010EDC: 50726F63 6573736F 72000000 462F5300 4E6F726D 616C0000 53797374 656D2043
5010EFC: 6F6D7061 6374466C 61736820 30000000 436F6D70 61637446 6C617368 20310000
5010F1C:  A556E6C 6F636B20 53504920 466C6173 68000000  A737069 5F616464 72203078
5010F3C: 2578203D 20307825 6C780000 45726173 696E6720 73656374 6F722066 726F6D20
5010F5C: 20307825 780A2000  A257320 2D20456E 64000000  A466169 6C20746F 20756E70
5010F7C: 726F7465 63742066 6C617368 20000000 2E2E2E4E 5652414D 2050726F 6772616D
5010F9C: 6D696E67 20466169 6C730A00 2E2E2E4E 5652414D 20457261 73696E67 20466169
5010FBC: 6C730A00 57726974 6520436F 6E666967 20466169 6C73202E 2E2E0A00  A696E76
---- block18  ptr=6005190  is_malloc=0  length=0x100 ----
6005150:        0        0        0        0        0        0        0        0
6005170:        0        0        0        0        0  6003D60  6005180  9DD36D0
6005190:        0        0  6005180  9700528  6003D60        0  57ED13C 1BFFB1E0
60051B0: 3C000000        0 20004E20 20004E20       84        2        2        1
60051D0:        0  9700520        0        0  1000000        0        0        0
60051F0:        0        0        0        0        0        0        0        0
6005210:        0        0        0        0        0        0        0        0
6005230:        0        0        0        0        0        0        0        0
6005250:        0        0        0        0        0        0        0        0
6005270:        0        0        0        0        0        0        0        0
---- block19  ptr=97B9A6C  is_malloc=0  length=0x100 ----
97B9A2C:        0        0        0        0        0        0        0        0
97B9A4C:        0        0        0        0        2        0        0        0
97B9A6C:  97B96AC  9700530  97B9A64  6D31580        8    10000        0        0
97B9A8C:  5160AB0  2851E0A   908774  6D31568        0        0        0  97B7D3C
97B9AAC:  97B7864  97B9AA0  6D31580        E    10000        0        0  5160B0C
97B9ACC:  2851E0A   908774  6D31568        0        0        0        0        0
97B9AEC:        0        0        0        0        0        0        0        0
97B9B0C:  5F69660        0        0        0        0        0        0        0
97B9B2C:        0        0        0        0        0        0        0        0
97B9B4C:        0        0        0        0        0        0        0        0
---- block20  ptr=97014F8  is_malloc=0  length=0x100 ----
97014B8:        0  97014F8  6004090  97014B4  6D31580        5    50000        0
97014D8:        0  5010EDC  2851E0A  2851E14  6D31568        0        0        0
97014F8:  9700530  97014BC  97014F0  6D31580        6    50000        0        0
9701518:  5010EDC  2851E0A  2851E14  6D31568        0        0        0        0
9701538: 1FC248F0       18      5C6 1FD7B1B8 1FD7B2D8 1FD7B3F8        0      300
9701558:        0        2        0        0        0        0        0        0
9701578:        0        0   1F3F22        0        0        0        0        0
9701598:        0        0        0        0        0        0        0        0
97015B8:        0        0        0        0        0        0   1F3F22        0
97015D8:        0        0        0        0        0        0        0        0
---- block21  ptr=6D31568  is_malloc=0  length=0x118 ----
6D31528:        0        0        0        0        0        0        0        0
6D31548:        0        0        0        0        0        0        0        0
6D31568:  28526AA  28525A2  2852450  2852236  28520D6  2851F4C  9DD36D8 1F698314
6D31588:        0        0        0        0        0    90000     259C        0
6D315A8:  5033F30  2851E0A  2851E14  6D31568        0     2EA2        0 1C173178
6D315C8: 1C16BBE0        0  5F690A0        0  5F6909C        0 43697363 6F20494F
6D315E8: 5320536F 66747761 72652C20 43333930 30652053 6F667477 61726520 28433339
6D31608: 3030652D 554E4956 45525341 4C4B395F 4E50452D 4D292C20 56657273 696F6E20
6D31628: 31352E31 2834294D 332C2052 454C4541 53452053 4F465457 41524520 28666331
6D31648: 290A5465 63686E69 63616C20 53757070 6F72743A 20687474 703A2F2F 7777772E
6D31668: 63697363 6F2E636F 6D2F7465 63687375 70706F72 740A436F
---- block22  ptr=DFDCB1C  is_malloc=0  length=0x100 ----
DFDCADC:        0        0        0        0        0        0        0        0
DFDCAFC:        0        0        0        0        0        0        0        0
DFDCB1C:        0        0        0        0        0        0        0        0
DFDCB3C:        0        0        0        0        0        0        0        0
DFDCB5C:        0        0        0        0        0        0        0        0
DFDCB7C:        0        0        0        0        0        0        0        0
DFDCB9C:        0        0        0        0        0        0        0        0
DFDCBBC:        0        0        0        0        0        0        0        0
DFDCBDC:        0        0        0        0        0        0        0        0
DFDCBFC:        0        0        0        0        0        0        0        0
---- block23  ptr=DF04B34  is_malloc=0  length=0x100 ----
DF04AF4:        0        0        0        0        0        0        0        0
DF04B14:        0        0        0        0        0        0        0        0
DF04B34:        0        0        0        0        0        0        0        0
DF04B54:        0        0        0        0        0        0        0        0
DF04B74:        0        0        0        0        0        0        0        0
DF04B94:        0        0        0        0        0        0        0        0
DF04BB4:        0        0        0        0        0        0        0        0
DF04BD4:        0        0        0        0        0        0        0        0
DF04BF4:        0        0        0        0        0        0        0        0
DF04C14:        0        0        0        0        0        0        0        0
---- block24  ptr=1FEB7948  is_malloc=0  length=0x100 ----
1FEB7908:        0        0        0        0        0        0    F423F        0
1FEB7928:        0 1FEB7834 1FEB7934        0        0        0        0        0
1FEB7948:        0        0        0        0        0        0        0        0
1FEB7968:        0        0        0        0        0        0        0        0
1FEB7988:        0        0        0        0        0        0    F423F        0
1FEB79A8:        0 1FEB78B4 1FEB79B4        0        0        0        0        0
1FEB79C8:        0        0        0        0        0        0        0        0
1FEB79E8:        0        0        0        0        0        0        0        0
1FEB7A08:        0        0        0        0        0        0    F423F        0
1FEB7A28:        0 1FEB7934 1FEB7A34        0        0        0        0        0
---- block25  ptr=20004E20  is_malloc=0  length=0x100 ----
20004DE0:        0        0        0        0        0        0        0        0
20004E00:        0        0        0        0        0        0        0        0
20004E20:    F423F        0        0 20004D34 20004E34        0        0        0
20004E40:        0        0        0        0        0        0        0        0
20004E60:        0        0        0        0        0        0        0        0
20004E80:        0        0        0        0        0        0        0        0
20004EA0:    F423F        0        0 20004DB4 20004EB4        0        0        0
20004EC0:        0        0        0        0        0        0        0        0
20004EE0:        0        0        0        0        0        0        0        0
20004F00:        0        0        0        0        0        0        0        0
---- block26  ptr=1BFFB1E0  is_malloc=1  length=0xA00 ----
1BFFB1A0:        0        0        0        0        0        0        0        0
1BFFB1C0:        0        0        0        0        0        0        0        0
1BFFB1E0: AB1234CD    F0000      12B  57819C4   9118C5 1C148688  970058C    A6A3C
1BFFB200:        0   911915  1000132 1EF66E34 DEADBEEF   911915        0  D0D0D0D
1BFFB220: 1F8FED44 20C9FBF8  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB240:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB260:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB280:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB2A0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB2C0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB2E0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB300:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB320:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB340:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB360:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB380:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB3A0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB3C0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB3E0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB400:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB420:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB440:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB460:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB480:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB4A0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB4C0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB4E0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB500:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB520:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB540:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB560:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB580:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB5A0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB5C0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB5E0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB600:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB620:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB640:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB660:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB680:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB6A0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB6C0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB6E0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB700:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB720:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB740:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB760:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB780:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB7A0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB7C0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB7E0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB800:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB820:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB840:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB860:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB880:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB8A0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB8C0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB8E0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB900:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB920:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB940:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB960:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB980:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB9A0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB9C0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFB9E0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBA00:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBA20:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBA40:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBA60:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBA80:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBAA0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBAC0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBAE0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBB00:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBB20:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBB40:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBB60:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBB80:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBBA0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1BFFBBC0:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
---- block27  ptr=9700950  is_malloc=0  length=0x100 ----
9700910:        0       F2       CD       F2       F2      117  970092C        0
9700930:        0        0        0        0  9700928        0        0        0
9700950:      118       F3      118      118      17B 1F398064        0        0
9700970:        0        0        0 1D9E4D2C  9700770  9700B30        0      17C
9700990:      119      17C      17C      23F 1F3AAE44        0        0        0
97009B0:        0        0 1F38E570        0        0        0      240      17D
97009D0:      240      240      2EF  97009E0        0        0        0        0
97009F0:        0  97009DC  970098C  9700A04        0      2F0      241      2F0
9700A10:      2F0      3E9 1F1DB834        0        0        0        0        0
9700A30: 1F1DB844        0        0        0      3EA      2F1      3EA      3EA
---- block28  ptr=1C1EC81C  is_malloc=0  length=0x100 ----
1C1EC7DC:        0        0        0        0        0        0        0        0
1C1EC7FC:  9DDF564        0        0        0     4200        0        0        0
1C1EC81C: 1C1ED414 1C1EC798 1C1EC814  6D31580       66    D0000        0        0
1C1EC83C:  5785E5C  2851E0A  2851E14  6D31568        0        0 1C1ECAB4        2
1C1EC85C: 1C1EC9FC        0        0        0        0        0        0        0
1C1EC87C:        0        0        0        0        0        0        0        0
1C1EC89C:        0        0        0        0        0        0        0        0
1C1EC8BC:        0        0        0        0        0        0        0        0
1C1EC8DC:        0        0        0        0        0        0        0        0
1C1EC8FC:        0        0        0        0        0        0        0        0
---- block29  ptr=1C1EC668  is_malloc=0  length=0x100 ----
1C1EC628:        2 1C1ED356  3010000   90E9A8   90EDAA  15FF18E   90E3B6   90E392
1C1EC648:   90EF04        0   90EAB8   90EB8E  15FF610  15FF3D2 1C1F398C 1C1F347C
1C1EC668: 1C1EC6EC 1C1ED4FC 1C1EC660  6D31580       6B    90000      121        0
1C1EC688:  5785E2C  2851E0A  2851E14  6D31568        0 1D88C628        0        0
1C1EC6A8:        0        0        0        0        0        0        0        0
1C1EC6C8:        0  9DDF564        0        0        0     4200        0        0
1C1EC6E8:        0  97B991C 1C1EC668 1C1EC6E4  6D31580       6C    D0000        0
1C1EC708:        0  5785E5C  2851E0A  2851E14  6D31568        0        0 1C1ED888
1C1EC728:        3 1C1ED790        0        0        0        0        0 15A3C78B
1C1EC748:        1  28869EE 1C1EB5F4        0        1 1C1ED36A  3010000  28437EE
---- block30  ptr=2B469480  is_malloc=0  length=0x100 ----
2B469440:        0        0        0        0        0        0        0        0
2B469460:        0        0        0        0        0        0        0        0
2B469480:        0        0        0        0        0        0        0        0
2B4694A0:        0        0        0        0        0        0        0        0
2B4694C0:        0        0        0        0        0        0        0        0
2B4694E0:        0        0        0        0        0        0        0        0
2B469500:        0        0        0        0        0        0        0        0
2B469520:        0        0        0        0        0        0        0        0
2B469540:        0        0        0        0        0        0        0        0
2B469560:        0        0        0        0        0        0        0        0
---- block31  ptr=262EFF00  is_malloc=0  length=0x100 ----
262EFEC0:        0        0        0        0        0        0        0        0
262EFEE0:        0        0        0        0        0        0        0        0
262EFF00:        0        0        0        0        0        0        0        0
262EFF20:        0        0        0        0        0        0        0        0
262EFF40:        0        0        0        0        0        0        0        0
262EFF60:        0        0        0        0        0        0        0        0
262EFF80:        0        0        0        0        0        0        0        0
262EFFA0:        0        0        0        0        0        0        0        0
262EFFC0:        0        0        0        0        0        0        0        0
262EFFE0:        0        0        0        0        0        0        0        0
---- block32  ptr=2097F464  is_malloc=0  length=0x100 ----
2097F424:        0        0 2097F334 2097F434        0        0        0        0
2097F444:        0        0        0        0        0        0        0        0
2097F464:        0        0        0        0        0        0        0        0
2097F484:        0        0        0        0        0        0        0    F423F
2097F4A4:        0        0 2097F3B4 2097F4B4        0        0        0        0
2097F4C4:        0        0        0        0        0        0        0        0
2097F4E4:        0        0        0        0        0        0        0        0
2097F504:        0        0        0        0        0        0        0    F423F
2097F524:        0        0 2097F434 2097F534        0        0        0        0
2097F544:        0        0        0        0        0        0        0        0
---- block33  ptr=2011CE78  is_malloc=0  length=0x100 ----
2011CE38:        0        0        0        0        0        0        0        0
2011CE58:        0        0        0        0        0        0        0        0
2011CE78:        0        0        0        0        0        0        0        0
2011CE98:        0        0    F423F        0        0 2011CDB4 2011CEB4        0
2011CEB8:        0        0        0        0        0        0        0        0
2011CED8:        0        0        0        0        0        0        0        0
2011CEF8:        0        0        0        0        0        0        0        0
2011CF18:        0        0    F423F        0        0 2011CE34 2011CF34        0
2011CF38:        0        0        0        0        0        0        0        0
2011CF58:        0        0        0        0        0        0        0        0
---- block34  ptr=1223BFA0  is_malloc=0  length=0x100 ----
1223BF60:        0        0        0        0        0        0        0        0
1223BF80:        0        0        0        0        0        0        0        0
1223BFA0:        0        0        0        0        0        0        0        0
1223BFC0:        0        0        0        0        0        0        0        0
1223BFE0:        0        0        0        0        0        0        0        0
1223C000:        0        0        0        0        0        0        0        0
1223C020:        0        0        0        0        0        0        0        0
1223C040:        0        0        0        0        0        0        0        0
1223C060:        0        0        0        0        0        0        0        0
1223C080:        0        0        0        0        0        0        0        0
---- block35  ptr=3AA38B2C  is_malloc=0  length=0x100 ----
3AA38AEC: 465EBC82 78F04D27  B2900F7 49FA3E7E D2D364E9 BEAF90BE D071E1F8 5D634958
3AA38B0C: C1CE4641  8B52DA8 6D55FF73  D8A362E 557042F3  D30D5CF A04863CB F9460185
3AA38B2C: 7B1BBBEE 9BF577FA 66FCC37D 7BBD4CED DBA632AD 6FA6DFEF 9BFF7135 DD7B2434
3AA38B4C: 97EE796A 2CDC4DDD ADBC2F64 8054A8B0 CA4F36E1 340BB31D F26A065F 2F6F5CFC
3AA38B6C: 5877DCEA 374905F7 9A424B94 BFF92788 3CA3D578 84F784B7 8F7B3A85 D8D0436E
3AA38B8C: 82339AD3 AA75D7F6 B2AF57BF 6EAABAAD 9C65565B 830A361C D3866219 9C9F2F7B
3AA38BAC: C84E86A7 9EAA4544 56951A8F D0A5C843 6C25B499 B78AAEF6 4A4EA0CA B3320607
3AA38BCC: D9AF1035 820B63D0 46343E9F 9215C7D4  4D983C6 81944989 C8B8835D 5C959298
3AA38BEC: 6230C4F8 BB5310CA C5385969 DED704AF 873A93CA A1C6D2E8 4683A170 D96B46FC
3AA38C0C: BB99FEBE 417F5FC1 9A1E8B93  EDF232B 67097A28 1C884CB3 B16BFA5B 91510ED5
---- block36  ptr=3117E51C  is_malloc=0  length=0x100 ----
3117E4DC:        0        0        0        0        0        0        0        0
3117E4FC:        0        0        0        0        0        0        0        0
3117E51C:        0        0        0        0        0        0        0        0
3117E53C:        0        0        0        0        0        0        0        0
3117E55C:        0        0        0        0        0        0        0        0
3117E57C:        0        0        0        0        0        0        0        0
3117E59C:        0        0        0        0        0        0        0        0
3117E5BC:        0        0        0        0        0        0        0        0
3117E5DC:        0        0        0        0        0        0        0        0
3117E5FC:        0        0        0        0        0        0        0        0
---- block37  ptr=35D53CF0  is_malloc=0  length=0x100 ----
35D53CB0:        0        0        0        0        0        0        0        0
35D53CD0:        0        0        0        0        0        0        0        0
35D53CF0:        0        0        0        0        0        0        0        0
35D53D10:        0        0        0        0        0        0        0        0
35D53D30:        0        0        0        0        0        0        0        0
35D53D50:        0        0        0        0        0        0        0        0
35D53D70:        0        0        0        0        0        0        0        0
35D53D90:        0        0        0        0        0        0        0        0
35D53DB0:        0        0        0        0        0        0        0        0
35D53DD0:        0        0        0        0        0        0        0        0
---- block38  ptr=26759484  is_malloc=0  length=0x100 ----
26759444:        0        0        0        0        0        0        0        0
26759464:        0        0        0        0        0        0        0        0
26759484:        0        0        0        0        0        0        0        0
267594A4:        0        0        0        0        0        0        0        0
267594C4:        0        0        0        0        0        0        0        0
267594E4:        0        0        0        0        0        0        0        0
26759504:        0        0        0        0        0        0        0        0
26759524:        0        0        0        0        0        0        0        0
26759544:        0        0        0        0        0        0        0        0
26759564:        0        0        0        0        0        0        0        0
---- block39  ptr=18AABB88  is_malloc=0  length=0x100 ----
18AABB48:        0        0        0        0        0        0        0        0
18AABB68:        0        0        0        0        0        0        0        0
18AABB88:        0        0        0        0        0        0        0        0
18AABBA8:        0        0        0        0        0        0        0        0
18AABBC8:        0        0        0        0        0        0        0        0
18AABBE8:        0        0        0        0        0        0        0        0
18AABC08:        0        0        0        0        0        0        0        0
18AABC28:        0        0        0        0        0        0        0        0
18AABC48:        0        0        0        0        0        0        0        0
18AABC68:        0        0        0        0        0        0        0        0
---- block40  ptr=12C4CC64  is_malloc=0  length=0x100 ----
12C4CC24:        0        0        0        0        0        0        0        0
12C4CC44:        0        0        0        0        0        0        0        0
12C4CC64:        0        0        0        0        0        0        0        0
12C4CC84:        0        0        0        0        0        0        0        0
12C4CCA4:        0        0        0        0        0        0        0        0
12C4CCC4:        0        0        0        0        0        0        0        0
12C4CCE4:        0        0        0        0        0        0        0        0
12C4CD04:        0        0        0        0        0        0        0        0
12C4CD24:        0        0        0        0        0        0        0        0
12C4CD44:        0        0        0        0        0        0        0        0
---- block41  ptr=1EFFF8B8  is_malloc=0  length=0x100 ----
1EFFF878:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1EFFF898:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1EFFF8B8:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1EFFF8D8:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1EFFF8F8:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1EFFF918:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1EFFF938:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1EFFF958:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1EFFF978:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
1EFFF998:  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D  D0D0D0D
---- block42  ptr=3D5C84B8  is_malloc=0  length=0x100 ----
3D5C8478: 2F672F0D 1233798C 541DD240 C3A22826 A81A77F5  644C69F 8BE65724 2B790B0B
3D5C8498: 92544208  9FD0B4C C04756AC 77E7786B 592A3CD5 C3F2D6AF 5DF296A5 7DBCB4DC
3D5C84B8: 3D81EAD1 ECBFF342 46F64198 8C11E941 9C2E6B55 645AEC7F DCBEA60E 501E5CDE
3D5C84D8: 7A8F9C5F C082D183  7EA4892 C7D0AC09 3B2C30AA  E29C0F3 A581E8E3 6F9A5954
3D5C84F8: CCCB3BC5 C5508A9B E65AD522 F8AA1EFD 7C290730 129C4E73 6DDBD09D 978BE3EE
3D5C8518: F31959C4 3C062872  10A4E3E D8B4FEC9 D1F20F52 96958DAA ECBBC049 2097AA30
3D5C8538: 1A7DDA0B 4A0F4F2D 1AB686FC  FEA69BB 39470DDE 7AC63827 EF901DB3 3A564546
3D5C8558: 7D3A74DB C113CD8C A2BAAE4E AB6320B3 B925CF64  4787437  750AF6E F1FAA39A
3D5C8578: 400F63CB 3155DA24 AC6E13EE A902574B 3E80D10A C8530F1D A3E2B087 E2596224
3D5C8598: BB4C3482 96366179 AB772D50 3426D91F C0C80084 45B0FA7E FFC12DA4 E5740E55
---- block43  ptr=119A0F84  is_malloc=0  length=0x100 ----
119A0F44:        0        0        0        0        0        0        0        0
119A0F64:        0        0        0        0        0        0        0        0
119A0F84:        0        0        0        0        0        0        0        0
119A0FA4:        0        0        0        0        0        0        0        0
119A0FC4:        0        0        0        0        0        0        0        0
119A0FE4:        0        0        0        0        0        0        0        0
119A1004:        0        0        0        0        0        0        0        0
119A1024:        0        0        0        0        0        0        0        0
119A1044:        0        0        0        0        0        0        0        0
119A1064:        0        0        0        0        0        0        0        0
---- block44  ptr=2FA65A9C  is_malloc=0  length=0x100 ----
2FA65A5C: 8206F057 B0062C03 4F8347B7  7EE7B84 3F657C19 E13F76EC 9C46CF61 F49C45CF
2FA65A7C: 51F49C44 CF41F49C 43CF31F4 9C42CF17 F4FC40CF  7B4AFA7 E700DABF D3730BED
2FA65A9C: D3691F1E  BFEE707 A6C3E79C 6C2D46C7 77B146A7 993DBFD5 29C260F2 45D7E48C
2FA65ABC: 358FCEA1 11B0F024 840F14C2 97733D0D 7AAEA0AF 9475A779 365829E8 ABB97F3E
2FA65ADC: A814F475 5C5F60EC 2BD50A7A 2DD757EA F44D5CAF D7E9755C DF8D749B  4BD9EEB
2FA65AFC: 87A1B709 FA56AEB7 199D9949 82BE8DE9 677A40CF 17F446AE 271A9D92 41D07771
2FA65B1C: 3D05BAE8 DFC47594 8F542FE8 BBB99E8F F8E708FA 1EAE63FC 78462C9F 66AE2F84
2FA65B3C: 7F9DA0B7 C8FAAE83 F3E873AE 82DE2A8F  FEFDD56 826DB6CA C7F8DE6D 12EC3DDC
2FA65B5C: 4E85DDCA 6D8C59CF 46723B19 762CB747 1A1D27DC DCB6414F E4368EDD F1C3DC46
2FA65B7C: 3ECF8EE4 36C6BD67 73B99D86 6DC7723B  576576E E7C28EE3 761EFCDD  6DD9F38
i3925E-0-(offline)#
Discriminator & Script
i3925E-0-(offline)#more Multiple-test.tcl
::cisco::eem::event_register_syslog pattern Configur
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
puts "START polycy \#1..."
i3925E-0-(offline)#sho run | inc  logg
PS.
Any syslog activation results in crash (cmd: send log "message" or ordinary syslog msg).
If you remove the logging discriminator or unregister policy - then all OK.
Policy with not a the syslog ED  don't lead to crash.
This is CSCts34693.  This will be fixed in the next 15.2T release.  There is no workaround, though I would not mix discriminator and EEM at this time.
Thanks Joseph!
Waiting for new release.
