EEM Script for license installation (multiple routers)
vishal-patil
I am fairly new to eem scripting. Can anyone help with writing eem script for copying license file from tftp to ISR 4k flash and then install the same (possibly for multiple routers)?
Joe Clarke
I don't know the exact commands you'd do, but this is a very simple workflow on the surface.  Something like this would get you started.
event manager applet install-license
 event none
 action 1.0 cli command "enable"
 action 2.0 cli command "copy tftp://10.1.1.1/isr.lic flash:" pattern "destination"
 action 2.1 cli command "isr.lic"
 action 3.0 cli command "license install ..."
Then you would run this with "event manager run install-license"
Thank you for your reply. I got everything figured out except coyping license file from tftp to flash. There are multiple license files (for each router).
I want to run this eem for multiple routers without hardcoding the filename.
You'll have to provide more information and show how you would do each step manually on a couple of routers.
