EEM script is aborting show command execution.
marumuga
Community Member
Hi ,
I have written small EEM script to debug the memory leak issue.
event manager applet snmp_logs
event timer watchdog time  1000
action 100 cli command "enable"
action 150 cli command "show processes memory detailed process iosd maps | append flash:snmp2.log"
"Show Processes memory...." command will take very long time to display the output. Hence EEM script is just aborting this command execution [ % Command aborted, execution status unknown ] .
Do you have any workaround for this issue.
Joe Clarke
Configure a higher maxrun time.  For example, allow two minutes:
event timer watchdog time 1000 maxrun 120
