EEM script on ASA 9.5
shinakuma123
Hi Guys
I have a ASA version 9.5 (2), supports EEM.
I would like to configure EEM to reset a site to site VPN tunnel every 30 min, essentially the following commands to be run:
Action 1 = Clear crypto isakmp sa
Action 2 = Clear cryptp ipsec sa peer x.x.x.x
I would like this to be run every 30 min.
Reason for this is, our tunnel between a ASA and a checkpoint hangs every so often, clearing both phase 1 and phase 2 resolves the issue.
its a bug which no one seems to have provided a fix for permanently so would like to implement this EEM in the meantime.
I have never dealt with EEM before and not familiar with the commands or structure, can anyone advise on the commands please!!
Many thanks
2 Accepted Solutions
Joe Clarke
This should work for you:
event manager applet period-event
event timer watchdog time 1800
action 1 cli command "clear crypto isakmp sa"
action 2 cli command "clear crypto ipsec sa peer x.x.x.x"
output none
This just needs to be configured in global mode.
Joe Clarke
output none
thank you Joe.
Is it a matter of just configuring the above in global configuration mode? and it will run from there forth or do I have manually tell the ASA to run the script somehow?
Please let me know if anything else is required to do.
