EEM Script to capture MAC address from syslog message
dgoodson
Hello All,
I need a script that matches a syslog message, extracts a mac address within the message and then runs a command for a variable matching the mac address. This is to be done on a WLC 5760 running 3.6.2. I need assistance with action 001 and setting up the correct regexp.
event manager applet Purge_IDLE_MAC
event syslog pattern "%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client b88d.1224.b75c, No response from platform"
action 001 regexp ???
action 002 syslog msg "Purging idle MAC $mac-address"
action 003 cli command "enable"
action 004 cli command "client mac-address $mac-address deauthenticate forced"
Dan Frey
Try this and use $mac as the variable name.
action 001 regexp "(b88d.1224.b75c)" "$_syslog_msg" match mac
Thanks for you reply… The mac address is the variable that I want to capture and its always changing. So, today we have several hundred messages, each different for that day. Whenever I get the message I want to capture that mac address variable from the log message and then execute my command using it.
For example:
244014: Jun 17 17:42:20: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client b88d.1224.b75c, No response from platform
244015: Jun 17 17:42:21: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client cc3a.61ba.f526, No response from platform
244016: Jun 17 17:42:24: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client 24ab.8177.2c42, No response from platform
244017: Jun 17 17:42:26: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client 34fc.eff3.8c48, No response from platform
244018: Jun 17 17:42:27: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client a4d1.d238.7039, No response from platform
244019: Jun 17 17:42:30: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client 5cf8.a1df.b1be, No response from platform
244020: Jun 17 17:42:41: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client 84b1.53c4.4025, No response from platform
244021: Jun 17 17:42:47: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client 783a.8404.10ac, No response from platform
244022: Jun 17 17:42:53: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client 9072.4060.36e3, No response from platform
244023: Jun 17 17:42:55: *%APF-4-WCDB_DEL_FAILED: 1 wcm:  Unable to delete client 78f7.bef5.cb7e, No response from platform
Then you want this regexp
regexp "([a-f0-9]+\.[a-f0-9]+\.[a-f0-9]+)" "$_syslog_msg" match mac
