EEM script to disable a module - triggered by log event
thoffman
Running VSS on 6509-e
We had the following waning below in the logs and less than 2 hours an event occured in which the transport between the CORE and Distro did not pass traffic.   Would like a EEM script to fire and shut down the module when this log event occurs. I've never setup an EEM script before and looking for some help.   Thanks
%CONST_DIAG-SW2_SPSTBY-4-ERROR_COUNTER_WARNING: Module 9 Error counter exceeds threshold, system operationcontinue.
config t
no power enable switch # module ##
In this case,
config t
no power enable switch 2 module 9
Joe Clarke
Try this script.
  It is my first time, how do you apply it to the 6509?  Do I tftp the .tcl on the distro?  How do I enable it?
First create a directory on flash called "policies".  For example:
mkdir disk0:/policies
Then, copy the script into this directory.  NOTE: since you have a VSS, you'll need to create the directory on both switches' flashes and copy the script into both locations.
Next, configure the following:
event manager directory user policy disk0:/policies
Finally, register the policy by configuring:
event manager policy sl_power_down_mod.tcl
