EEM script using up all VTY lines. Why?
thomasdzubin
In one of my router's logs, I saw:
000910: Dec 31 23:59:00.405 MST: %HA_EM-3-FMPD_CLI_CONNECT: Unable to establish CLI session: no tty lines available, minimum of 2 required by EEM
so I logged into it (an 1811W running IOS 12.4(11)XW5) yesterday and when I did a "show user" I saw this:
SAFRTR#show user
Line User Host(s) Idle Location
6 vty 0 idle 2w5d EEM:testemailapplet
7 vty 1 idle 2w4d EEM:testemailapplet
8 vty 2 idle 2w3d EEM:testemailapplet
9 vty 3 idle 2w2d EEM:testemailapplet
10 vty 4 idle 2w1d EEM:testemailapplet
11 vty 5 idle 2w0d EEM:testemailapplet
12 vty 6 idle 1w6d EEM:testemailapplet
13 vty 7 idle 1w5d EEM:testemailapplet
14 vty 8 idle 1w4d EEM:testemailapplet
15 vty 9 idle 1w3d EEM:testemailapplet
16 vty 10 idle 1w2d EEM:testemailapplet
17 vty 11 idle 1w1d EEM:testemailapplet
18 vty 12 idle 1w0d EEM:testemailapplet
19 vty 13 idle 6d08h EEM:testemailapplet
* 20 vty 14 gtisupport idle 00:00:00 xxx.x.xxx.x
So it looks like my EEM applet is not exiting after it runs and freeing up the VTY... I don't understand why... it works just fine: every night at midnight it sends me an email with the output of CLI commands "show ip accounting" and "show interface FastEthernet0" and then clears the stats... here is the script:
event manager environment _mail_domain xxxxxxxxxxxxx.org
event manager environment _mail_smtp emailserver
event manager environment _mail_rcpt gtisupport@xxxxxxxx.com
event manager applet testemailapplet
event timer cron name "_EEMinternalname0" cron-entry "59 23 * * *" maxrun 9999999
action 1.0 info type routername
action 1.5 cli command "enable"
action 2.0 cli command "show ip accounting"
action 3.0 mail server "$_mail_smtp" to "$_mail_rcpt" from "$_info_routername@$_mail_domain" subject "show ip accounting" body "$_cli_result"
action 4.0 cli command "clear ip accounting"
action 5.0 cli command "show interface FastEthernet0"
action 6.0 mail server "$_mail_smtp" to "$_mail_rcpt" from "$_info_routername@$_mail_domain" subject "show int FE0" body "$_cli_result"
action 7.0 cli command "clear counter FastEthernet0"
action 8.0 cli command "exit"
end
Any thoughts?
Collin Clark
Try entering these two commands in your router config, they will terminate "disconnected" sessions.
service tcp-keepalives-in
service tcp-keepalives-out
Hope that helps.
Joe Clarke
It's action 7.0 that's causing the problem. This command is interactive, and causing your policy to stall. Try doing this:
action 7.0 cli command "clear counter FastEthernet0/0" pattern "confirm]"
action 7.1 cli command "y"
That should fix you up.
Yes, that did the trick! Thanks!
