EEM scripts Doubt
nishanthbabuece1
Frequent Visitor
Frequent Visitor
I want the below script to be applied only to particular ports of my 24-port switch. I don't want this to be applied to all my gigabit ports. Help me to make small changes in the script.
Example : I don't want the script to be applied to port 5-10 and port 12.
event manager applet update-port-description
event neighbor-discovery interface regexp GigabitEthernet.* cdp add
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "interface $_nd_local_intf_name"
action 4.0 cli command "description $_nd_cdp_entry_name:$_nd_port_id"
Output :
description SDCC_IDF_1.11:TenGigabitEthernet0/1
brselzer
You can use the regex part of the trigger to filter out the interfaces you don't want:
event neighbor-discovery interface regexp GigabitEthernet0\/([1-5]\s|1[1,3-9]|[2][0-4]) cdp add
This should trigger only when an interface that starts with Gig0/1-5,11,13-24 comes up. You can double check my regex to be sure.
Hope that helps!
-Bradley Selzer
CCIE# 60833
brselzer
Hope that helps!
-Bradley Selzer
CCIE# 60833
