12-09-2009 07:14 AM
Correct me of Im wrong, but whenever one enables a certain technology or protocol on a Cisco device, the option exists to monitor the behavior through SNMP.
The example I am concerned with in particular is MQC QoS.
I have read in many documents that Cisco has an SNMP MIB for MQC QoS, but how does one go about enabling that MIB so that an NMS station can leverage it to monitor....
I would think that one would have to enable the traps under the "snmp-server" set of congiurations, but no matter what version of code I use to check, there is never an option for enabling MQC QoS traps, even though the technology is configurable on the device.
Example:
3#conf t
Enter configuration commands, one per line. End with CNTL/Z.
3(config)#snmp-server enable traps ?
alarms Enable SNMP alarms traps
atm Enable SNMP atm traps
bgp Enable BGP traps
bridge Enable SNMP STP Bridge MIB traps
bulkstat Enable Data-Collection-MIB Collection notifications
c6kxbar Enable SNMP CISCO-CAT6K-CROSSBAR-MIB traps
call-home Enable SNMP CISCO-CALLHOME-MIB traps
casa Enable SNMP casa traps
cef Enable SNMP CEF traps
chassis Enable SNMP chassis traps
config Enable SNMP config traps
config-copy Enable SNMP config-copy traps
config-ctid Enable SNMP config-ctid traps
cpu Allow cpu related traps
csg Enable SNMP CSG traps
dhcp Enable SNMP dhcp traps
dot1x Enable SNMP dot1x traps
ds1 Enable SNMP DS1 traps
eigrp Enable SNMP EIGRP traps
entity Enable SNMP entity traps
envmon Enable SNMP environmental monitor traps
ether-oam Enable SNMP ethernet oam traps
ethernet Enable SNMP Ethernet traps
event-manager Enable SNMP Embedded Event Manager traps
flash Enable SNMP FLASH notifications
flex-links Enable SNMP FLEX Links traps
frame-relay Enable SNMP frame-relay traps
fru-ctrl Enable SNMP entity FRU control traps
hsrp Enable SNMP HSRP traps
ipmulticast Enable SNMP ipmulticast traps
ipsec Enable IPsec traps
isakmp Enable ISAKMP traps traps
isis Enable IS-IS traps
l2tun Enable SNMP L2 tunnel protocol traps
mac-notification Enable SNMP MAC Notification traps
memory Enable SNMP Memory traps
module Enable SNMP module traps
mpls Enable SNMP MPLS traps
msdp Enable SNMP MSDP traps
mvpn Enable Multicast Virtual Private Networks traps
ospf Enable OSPF traps
pim Enable SNMP PIM traps
port-security Enable SNMP port security traps
pppoe Enable SNMP pppoe traps
pw Enable SNMP PW traps
rep Enable SNMP Resilient Ethernet Protocol Traps
resource-policy Enable CISCO-ERM-MIB notifications
rf Enable all SNMP traps defined in CISCO-RF-MIB
rsvp Enable RSVP flow change traps
rtr Enable SNMP Response Time Reporter traps
slb Enable SNMP SLB traps
snmp Enable SNMP traps
sonet Enable SNMP SONET traps
stpx Enable SNMP STPX MIB traps
syslog Enable SNMP syslog traps
transceiver Enable SNMP transceiver traps
tty Enable TCP connection traps
vlan-mac-limit Enable SNMP L2 Control VLAN MAC Limit notifications
vlancreate Enable SNMP VLAN created traps
vlandelete Enable SNMP VLAN deleted traps
vtp Enable SNMP VTP traps
<cr>
12-14-2009 03:37 PM
The first thing to do to enable SNMP, is to configure a community string (for SNMPv2c and SNMPv1). Most platforms accept the following command:
# snmp-server community test ro
where, 'test' is the community name and 'ro' stands for read-only. More info on the IOS syntax is here:
http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_17.html#wp1102590
Some SNMP setup configuration examples can be found here as well:
http://www.cisco.com/en/US/docs/ios/12_2/configfun/configuration/guide/fcf014.html#wp1001599
Now, for the QoS functionality, it is mostly kept inside the CISCO-CLASS-BASED-QOS-MIB (.1.3.6.1.4.1.9.9.166).
Once your device is enabled for SNMP access, you should be able to query the MIB above for some QoS information.
The amount of data in this mib is quite large, so it basically depends on what information you want to get.
For example:
cbQosServicePolicyTable gets you: the interfaces/media types and the policymap that are attached to it.
cbQosATMPVCPolicyTable gets you: the policies that are attached to a ATM PVC.
cbQosPolicyMapCfgTable gets you: the Policymap configuration information.
cbQosCMStatsTable gets you: ClassMap related Statistical information.
cbQosQueueingStatsTable gets you: Queueing Action related Statistical information.
So as you can see, there is a big amount of info you can get off your device for QoS.
Perhaps a CLI command used would help narrow down the objects needed.
Hope this helps.
Luis.
12-14-2009 03:48 PM
Sorry, forgot to comment on the SNMP QoS traps. Unfortunately, there are no native QoS traps available at the moment.
However, RMON could be used to monitor specific OIDs in the CISCO-CLASS-BASED-QOS-MIB so an RMON trap can be sent whenever the value reaches a specified threshold.
Info on RMON config can be found here: http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_cfg_rmon_sup_ps6350_TSD_Products_Configuration_Guide_Chapter.html
