Energywise - catalyst 3560
IvanSipos
I have installed the evaluation version of EnergyWise orchestrator in a vmware server
the pc is logged in the application with the Cisco client installed
when I try to register the 3560 switch do not appear in the application.
Can you help me.
Thanks and regards,
Ivan,
can you help me with the installation guide? or how is the process to install the cisco orchestrator?
thanks
the comptible 3560 are:
https://www.cisco.com/en/US/docs/switches/lan/energywise/phase2/orchestrator/release/notes/ol19815.html
I have a similar issue , i am trying to register the switch to the orchestrator but i have no luck , what is the minimum config on the switch to get this to work and how do i configure the provisioning server for this.
Guys,
any idea on how to install cisco orchestrator?
