11-22-2013 01:53 AM
We are looking at the energywise commands on our switches to power off some ports over night. We have successfully powered off some ports, however if we want to make changes to say the times then it seems that we have to edit each port individually. Is there a way that you can configure say a group that ports belong to for energywise and link to a single time range?
Solved! Go to Solution.
11-22-2013 01:58 AM
Please follow these threads;
Https://supportforums.cisco.com/thread/164684
Https://supportforums.cisco.com/thread/2104246
Hope it helps
Don't forget to rate helpful posts
11-22-2013 01:58 AM
Hope it helps
11-22-2013 02:15 AM
11-22-2013 02:31 AM
Glad that you found your solution.
