Showing results forĀ
Search instead forĀ
Did you mean:Ā
Errdisable recovery cause mac-limit
I will configure "errdisable recovery cause mac-limit" but where it will get its mac-limit? Is it on "switchport port-security maximum <number>"?
What will be the cons of using "errdisable recovery cause mac-limit"?
In configuration of port-security on interface
switchport port-security maximum...
Milos Megis
Level 3
Level 3
If you use errordisable recovery... then in case that port will go to err-disable state, it will be automatically activated after configured period of time (default is 300 seconds, I think).
Otherwise you have to go to configuration of interface and type commands shutdown and then no shutdown to activate it
But where you set the mac limit?
