Error occurred while retrieving total power consumption of the selected domain.
bebygone24
Hello guys,
need ur help,
i  got a problem when using energywise feature on LMS 4.1 as a power   consumption monitoring. currently, i just want to monitor our   network-device power consumption everyday. the problem is , LMS seem   intermittent to fetch data from my network device & its endpoint  (IP  phone) , as a result : LMS displayed incorrect data. see the  different  between the 2 tables below.
at first, we got a good result, seem like LMS can monitor our devices power-consumption correctly.
but several hours later, LMS stop to monitor  the device :
any suggestion will be appreciated.
bebygone24
did anyone have the same problem ?
it seem like my LMS is getting busy to retrieve the power consumption of  each device. i have to reload the my server to make it back to the  normal.
