Etherchanneling (Cisco 6509)
nizan1342
I have a Cisco 6509 (running: WS-C6509 Software, Version NmpSW: 8.2(2)) and I want to set up etherchanneling on two ports located on our 10/100/1000 blade:
(enable) show mod 2
Mod Slot Ports Module-Type Model Sub Status
2 2 48 10/100/1000BaseT Ethernet WS-X6148-GE-TX no ok
.. I am hopeing someone can verify the steps to do this as what i've done doesn't seem to improve thruput any:
set port lacp-channel 2/3-4 573
set port lacp-channel 2/3-4 mode on
(enable) show lacp-channel group 573
Admin Port Channel LACP Port Ch Partner Oper Partner
key Mode Priority id Sys ID Port
573 2/3 on 128 1699 0:00-00-00-00-00-00 0
573 2/4 on 128 1699 0:00-00-00-00-00-00 0
If someone can confirm/correct what i've done, I'd greatly appreciate it.
Thanks!
steve.busby
Level 5
Level 5
If this etherchannel is between two CatOS devices, use PAgP, if one device is CatOS and some other vendor use LACP. Follow the appropriate section in this link:
http://www.cisco.com/en/US/partner/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007ec1c.html#xtocid2376022
