Event Detector Identity - match aaa-attribute
radek_rams
I want to catch event when endpoint receive specific aaa-attribute (vlan assignment).
I've tried syntax below but without success:
event identity interface regexp .* authz-complete aaa-attribute Tunnel-Private-Group
What is a valid name for aaa-attribute?
Second question: identity detector has variable  $_identity_<attribute>
How to access this variable? If Tunnel-Private-Group would be correct then variable has name $_identity_Tunnel-Private-Group?
I did "debug event manager all" but culdn't found such data, only this:
000287: May 13 10:34:18.430: EEM: policy_dir xml builtin: name:_event_type value:291
000288: May 13 10:34:18.430: EEM: policy_dir xml builtin: name:_event_type_string value:identity
000289: May 13 10:34:18.430: EEM: policy_dir xml builtin: name:_event_severity value:severity-normal
000290: May 13 10:34:18.430: EEM: policy_dir xml builtin: name:_identity_stage value:authz-complete
000291: May 13 10:34:18.430: EEM: policy_dir xml builtin: name:_identity_status value:success
000292: May 13 10:34:18.430: EEM: policy_dir xml builtin: name:_identity_interface value:GigabitEthernet1/0/18
000293: May 13 10:34:18.430: EEM: policy_dir xml builtin: name:_identity_mac value:xxxx.xxxx.xxxx
0 Replies 0
