Expect scripting issue
pantelis1
Level 3
Level 3
Hi All
I am in the process of creating an expect script to capture the output of show commands from various devices and output them as <name of the device>.<command>.txt
However, I am having the following issues:
  1. The "show commands" on the script are not always parsed correctly on the routers (for example the "show ip route" might be parsed as "how ip route" and therefore generate an error)
  2. The output file has the correct format but there is no output within the file
Could you please review and assist in the issues above?
#!/usr/bin/expect
# Here, we specify all our commands in a list, that we will issue one
# by one at a later time.
set commands {
"show ip route"
"show ip int brief"
"show arp"
# Set the date.
set date [timestamp -format %C%y%m%d]
# This variable is for a file called *.txt that has the IP
# of all of the routers you are collecting information from.
set device_list [read [open "routers.txt"]]
# Specify password, as well as what we expect the routers'
# prompt to be.
set pass "*********"
set prompt "#"
# This command tells expect not to echo the output to the console.
exp_log_user 0
# We loop through each device in our list, one by one...
foreach device $device_list {
# Set each device's log file to be the name of the device...
set file_name "$device.txt"
# we initiate the SSH connection
spawn ssh $device -l *********
#If we see a message asking about the device's host key, accept it.
expect -re "Password:" {
exp_send "$pass\r"
#exp_send "terminal length 0\n"
foreach cmd $commands {
expect -re $prompt {
exp_log_file -a $file_name.$cmd
exp_send "$cmd\r"
#exp_sleep 2
exp_log_file
#expect -re $prompt {
#send "term len 0\r"
exp_send "logout\r"
# Turn off logging.
exp_log_file
close
Pantelis
22 Replies 22
This is what I meant by adding the close:
#!/usr/bin/expect
set commands [list "sh ip route summary" "show interfaces" "show arp" "sh ip ospf neighbor" "sh ip eigrp neighbor" "sh cdp neighbors"]
# Set the date.
# This variable is for a file called switches.txt that has the hostname/IP
# of all of the routers you are collecting information from.tepad
set device_list [read [open "switches.txt"]]
# Specify password, as well as what we expect the switch
# prompt to be.
set pass "********"
#set prompt "#"
set prompt {([#>]) ?$}
#exp_log_user 0
#log_user 1
set file_name $device
eval spawn ssh $device -l ******
match_max [expr 32 * 1024]
interact -o -nobuffer -re "assword: $" return
send "$pass\r"
# We log our output from each router to its specified file.
#exp_log_file -a $file_name.$date
# Loop through each command that we specified earlier.
expect -re $prompt
send "term len 0\r"
expect -re $prompt
send "$cmd\r"
expect -re $prompt
#remove zeros from the cmd filename
regsub -all {[ \r\t\n]+} $cmd "" correct_cmd
set output $expect_out(buffer)
set fd [open $file_name-$date-$correct_cmd.txt w]
puts $fd $output
close $fd
expect -re $prompt
send "exit\r"
close
same issue Joseph. The host is been used as a hop to ssh to the next one
#spawn ssh 10.x.xx.xx -l *****
Hi, instead of close, do:
exp_close -i $spawn_id
exp_wait
same issue
code has been amended to :
expect -re $prompt
send "exit\r"
send "$cmd\r"
expect -re $prompt
puts $fd $output
close $fd
expect -re $prompt
send "exit\r"
exp_wait
Could you post the full version of the current code you have (without any sensivite information of course..)?
Hi Toni
#!/usr/bin/expect
# Set the date.
# of all of the switches you are collecting information from.tepad
# Specify the username and password, as well as what we expect the routers'
# prompt to be.
set pass "*******"
#set prompt "#"
#exp_log_user 0
#log_user 1
send "$pass\r"
expect -re $prompt
send "term len 0\r"
expect -re $prompt
send "$cmd\r"
expect -re $prompt
puts $fd $output
close $fd
expect -re $prompt
send "exit\r"
exp_wait
Pantelis
I tried your code and it appears like the host #1 is used to connect to the host #2. BUT it only appears like it because:
In reality the connection to host #2 does not originate from the host #1 but from the host you are running the script from.
To clarify, IOS doesn't have a command named "spawn"... so the command would simply fail if you were trying to connect to the host #2 from host #1 using that command.
The code you supplied works for me, all I did was to change the username and password, the code successfully creates files for both the devices I had in the txt-file for the supplied show-commands.
If your experiences differ from mine, I'd next check that you are running the latest versions of expect etc.
Hi Toni
My only concern was the fact that I could see # when running the command. However, it does make sense as the IOS doesn't know what "spawn" is.
