Exporting ACS users
dave.horn
Visitor
We're running ACS 3.2 on an IBM server and I was wondering if it would be possible to export the users in a group to a file? Thx
David Stanford
you can try the following from the command line to export:
"CSUtil -d filename"
Then to import:
"CSUtil -i filename"
