Exporting heat maps in Prime Infrastructure 3.1
spfister336
Level 2
Level 2
Is there no way to export heat maps in jpg/png/etc from Prime 3.1? The export maps function doesn't do this (I need a graphic to include in a report, not data files to import into something else). The export PDF function only exports what is currently visible on the screen, which I think seems slightly useless.
0 Replies 0
