failover on 2811 with 2 ISPs
k_romych
I have a cisco 2811 router with 2 wan ethernet ports and 4 lan ethernet ports, 2 internet connections (1 is FTTC (vdsl) connection so I configured pppoe dialer and 2 is Virgin media connection to the VM router so its simple ethernet connection with static public ip address) , both connections works fine.
I configured local network with NAT on FTTC connection (tried it on VM as well) and that workes fine as well.
What I am trying to achive is  use wan1 (fttc) connection by default for NAT and if it goes down - switch to wan2 automaticaly.
Idealy I would need to have part of local network to be NATing to wan1 and, if wan1 goes down, failover to wan2 and other part of local network to NAT to wan2 and, if wan2 goes down, to failover to wan1.
Router details: Version 12.4(13r)T
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-advipservicesk9-mz.124-12.bin"
I configured the router as in example below using route maps and track command and the issue is that dialer (wan1 fttc connection) goes down, it swithes over to wan2 and doesnt go back to wan1 (dialer), its just doesnt dial fttc connection.
  this is my config:
interface FastEthernet0/0
description FTTC
no ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0/1
description $ETH-WAN$
ip address 94.174.*** 255.255.255.248
ip nat outside
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname ***********@itp.4adsl.net
ppp chap password 0 *****
ppp ipcp dns request
route-map VIRGIN permit 10
match ip address 1
match interface fast 0/1
exit
route-map ENTA permit 10
match ip address 1
match interface Dialer1
exit
ip nat inside source route-map VIRGIN interface FastEthernet 0/1 overload
ip nat inside source route-map ENTA interface Dialer1 overload
ip sla 100
icmp-echo 4.2.2.2 source-interface Fastethernet0
timeout 500
frequency 3
track 100 rtr 100 reachability
delay down 10 up 20
ip route 0.0.0.0 0.0.0.0 Dialer1 track 100
ip route 0.0.0.0 0.0.0.0 FastEthernet 0/1 94.174.**** 10
Any input would be appriciated
0 Replies 0
