FDM Email Notification Problem
mohamed-elsherif
Community Member
Hello every one
i have configured my cisco LMS Email Notification Group and evrything works fine sending and receving ,  excpet that the FDM sent the Email without displaying the Device Name only the IP address in the Object ID .
AFROJ AHMAD
Hi Mohamed,
By deafult DFM does not use the DCR Display Name. check the below link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_device_fault_manager/3.2/user/guide/useDevMg.html#wp1367517
To overcome this :
1> Added the Device Name and IP address on the DNS Server
2> Modified NMSROOT/objects/smarts/conf/discovery/discovery.conf, and changed the DisplayNameFormat from "AUTOASSIGNED" to "MIBIISYSNAME".
That caused DFM to display the sysName as the display name.
Also set the NameFormat to TM_USEAUTONAME, then restarted daemon Manager (net stop crmdmgtd && net start crmdmgtd )
Open name-resolver.conf file and make same changes that we have made in  discovery.conf.  ie, the following entry should be there in this file  also.
  #NameFormat = "TM_USESEEDNAME"
  NameFormat = "TM_USEAUTONAME"
3> Delete and re-add a device in DFM
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
