FlashClean up Template for Prime Infrastructure
c0x10
Im am playing since a while with templates in prime infrastructure and deploy it to my switches.
Now I want to create another template to clean the flash from old images with the following command:
request platform software package clean switch all file flash:
But I am not sure how the cli template should be for prime.
Someone has maybe a solution and can point me to the correct solution.
Hope this is possible to do?
Thx in advance
0 Replies 0
