Flexible NetFlow Configuration
zekebashi
Level 8
Level 8
I was trying to configure Flexible Netflow on C9500 running Fuji 16.09.04 and ran into an issue. When I try to assign an ip flow monitor to an SVI, the command is rejected. Here's the output from the cli "SW-A(config-if)#ip flow monitor standardMonitor input % Flow Monitor: Failed to add monitor to interface: flexible netflow not supported on vlan interfaces.
Here's the Flexible Netflow configured:
flow record "standardRecord"
match ipv4 source address
match ipv4 destination address
match ipv4 protocol
match transport source-port
match transport destination-port
match ipv4 tos
match interface input
match interface output
collect counter bytes long
collect counter packets long
flow exporter "standardExporter_UDP_9995"
destination 10.1.10.40
source Loopback100
transport udp 9995
export-protocol netflow-v9
flow exporter "standardExporter_UDP_2055"
destination 10.1.10.176
source Loopback100
transport udp 2055
cache timeout active 60
interface Vlan110
!!!!!!!!! Error produced!!!!!
Any ideas?
Thanks in advance,
~zK
Yes, you can do it to different monitos and/or vlans. Use the same syntax.
Mark as solved and helpful it, it will help other users
Jaderson Pessoa
*** Rate All Helpful Responses ***
Jaderson Pessoa
try it:
vlan configuration   1,2,3-5  ( choice your vlans )
Jaderson Pessoa
Thanks for your response. That didn't work! Here's the output produced after applying your suggested configs:
SW-A(config-vlan-config)#ip flow monitor standardMonitor input
% Flow Monitor: Flow Monitor 'standardMonitor' Unsupported key field "interface output" for ip traffic in Input direction
DMZSW-A(config-vlan-config)#ip flow monitor standardMonitor out
% Flow Monitor: Flow Monitor 'standardMonitor' Unsupported key field "interface input" for ip traffic in Output direction
Any other ideas?
Best, ~zK
OK, so I had to create a user-defied records and use the command you suggested and that worked. However, the use of that command seem to have created a new command/syntax in the running configuration file which I have never seen before nor do I understand what it does. Is this command linked to the L3 VLAN 110 or L2 VLAN 110?
vlan configuration 110
ip flow monitor MONITOR_IN input
ip flow monitor MONITOR_OUT output
||||||||||||  Flexible Netflow Commands used |||||||||||||
flow record RECORD-IN
match flow direction
match ipv4 protocol
match ipv4 tos
collect interface output
collect transport tcp flags
flow record RECORD_OUT
match ipv4 protocol
match ipv4 tos
collect interface input
flow exporter Exporter_UDP_9995
 destination 10.1.6.40
 source Loopback100
 transport udp 9995
flow exporter Exporter_UDP_2055
 destination 10.1.6.176
 source Loopback100
 transport udp 2055
cache timeout inactive 10
record RECORD_IN
record RECORD_OUT
SW-A#config t
SW-A(config-vlan-config)#vlan configuration 110
SW-A(config-vlan-config)#ip flow monitor MONITOR_IN input
SW-A(config-vlan-config)#ip flow monitor MONITOR_OUT output
Thanks in advance, ~zK
Jaderson Pessoa
