Get configuration backup using ansible
yuganwimukthi
I created a playbook for cisco router configuration backup but after executing my command below error occurred.i'm a new user for Ansible hence please help me to solve this problem.
fatal: [xx]: FAILED =>["changed": false, "msg": "unable to elevate privilege to enable mode, at prompt [xxxx] with error: failed to elevate privilege to enable mode still at promt [xxx]
 This is not an Ansible problem. The message seems clear, the script try to run the command "enable" and had no privilege. Probably the user you are using to connect to the device has no privilege.
yuganwimukthi
Dear Flavio Maranda,
Thank you for your feedback. I enabled my router secret password after that playbook worked properly.
fmugambi
How does your playbook look like, am stuck with same problem, but different error,
