gNMI on switch IE3000
cisco49
Hi, I need to enable gnxi on switch IE3000
I followed same instructions on all my other cisco catalyst switch but on the last one, an IE3000, I can't connect on port where gnxi is listening
With the command
    show ip ports all
I see the port opened but when I try to connect to it, I get connection refused
Below are the settings that I used
   gnxi
   gnxi port 9340
   gnxi server
Can someone help me?
11 Replies 11
There isn't a firewall or an ACL between the host and the switch
I however started a trace on perimeter firewall, but no traffic went throught it
@cisco49
Which IOS version do you have on this switch?
Cisco IOS XE Software, Version 17.06.03
The switch exact model is  IE-3300-8U2X
check and see if you have this command
show platform software yang-management process
confd : Running
nesd : Running
syncfd : Running
ncsshd : Not Running
dmiauthd : Running
nginx : Running
ndbmand : Running
pubd : Running
gnmib : Running
below there is the output of command:   show ip ports all
tcp6 :::9340 :::* LISTEN 27538/gnmib
@cisco49
Try to use a different port for testing
nxi port 50000
I already tried it but it didn't work
This is the only switch of this model or do you have more?
Unfortunately we have only one switch with this model
We have several other catalyst 9200 and 9300 without this problem
They are on the same subnet and vlan
I dont see on the data sheet anything mentioning support for gNMI . But, if you have the command and considering the IOS version, it should work.
 Which license do you have on this switch?
Hi Flavio,
I have the essential license
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
dna-essentials Subscription Smart License dna-essentials
same as on the other switch
