Help desk users reset port security
ckgilliam
I`m looking for a way through Cisco
works for helpdesk users to be able to reset port-security
Nael Mohammad
Level 5
Level 5
You can create a user defined task that in RME that basically  does a shutdown and no shutdown to the interface under one job .
Or use CiscoView --> Select the device ---> Right Click the network interface that is disabled.Choose configure --> a popup will appear,  select the interface and in the field labeled "Admin Status" choose "down" click apply. Do the steps again and in the admin status field, choose "up" and click apply. This should reset the port security.
Hi.
I have done what you indicate using CiscoView but only off and on the port. I want you to clean mac that are anchored in that port.
This is more than a 4 years old post.
You should start a new discussion for any help further. You can refer old posts via their links.
Your posts on old discussions may not be visible to many people and it would reduce chance of getting the problem solved.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
