Help with designing a network: 3 WANS, Multiple WiFi and LAN Clients
QuintonDkock
Hello Everyone,
I currently have the following setup: 3 WANS terminated as Ethernet from my provider. They have their own routers installed which I can get removed but for now that's how the termination is being done.
What setup would be a favorable one for me owing to the following points:
  1. I want a central interface router where I can assign WANs to the LAN clients connected to the router. (e.g. Switch Port 1-2 gets routed to WAN 1, etc.)
  2. I optionally want to setup a load balancer between the three WANs with my own priority.
My WANs are 30 Mb/s each.
most (even the smaller) Cisco routers can do what you want, so it comes down to the budget you have. Have a look at the ASR/ISR 1000 series.
