Hi to all,
as i was looking in two of our switches i found out that Prime "decided" for the first switch to assign a VoIP Phone port as link port and in another switch which had exactly the same configuration in the voip port as the first switch , Prime categorized this port as access port.
What are the criteria that Prime uses in order to categorize link ports? And why Prime failed to categorize the exact same port in two different switches as link port in the first one and as access port in the second one?
Ditter
