How I used pyats pcall to sync my live switch data into Netbox.
tmrmoonil
How I solved the "stale NetBox data" problem for my existing network. I put together a Python script that uses pyATS `pcall` to connect to all my switches at once (way faster than 1-by-1) and automatically syncs their live port status, VLANs, and descriptions back to NetBox. I made a short video walking through the code and logic, thought it might be useful to others trying to do the same or show how you can use pcall to do multithreading to retrieve data
https://youtu.be/o-oLZojAxbUhttps://youtu.be/o-oLZojAxbU
0 Replies 0
