Class_Lab
RixSnoopy
Community Member
 Someone please help me with this Please. I tried configurations and try pinging from one PC to another PC in another vlan but "request timeout". I'm confused what to do firstly.
6 Replies 6
Can you provide your configurations or Packet tracer file in .zip format so we can better assist?
In the meantime you can check the following common issues:
-Are all VLANS needed created on all switches and allowed on the necessary trunk links?
-Are IPS and default Gateways correct and in the same subnet? Can each PC ping their own default GW? If not start there.
-How are the 2 separate networks learning about each other? Did you enable routing with static routes or a routing protocol?
Hope that helps
-David
PCs in their own vlans can ping each other But, eg; from vlan 2 PCs to
other vlan PCs won't ping.
I'm attaching the zip.file.
Thanks for your response.
Not sure if you have attached your file but I do not see it. Can the PCs ping their own Default Gateway?
Yes the PCs in each vlans can ping their own gateway
elwin-berrar
Level 2
Level 2
You need to enable ip routing on the L3 switch for the SVIs to actually route traffic between VLANs.
See
https://www.ciscopress.com/articles/article.asp?p=3089357&seqNum=6
https://pingmynetwork.com/network/ccna-200-301/intervlan-routing
You really clarified everything.
Thank You for your help.
