How to conduct attack surface mapping
kamranshareef
I need guidance to conduct attack surface mapping, I have my network topology diagram ready. My task is to "identify potential vulnerabilities and weaknesses within the network architecture and design,
considering factors such as unauthorized access, data breaches, and network availability"
M02@rt37
Hello @kamranshareef,
General guidelines:
--Make a list of all the assets (e.g., servers, workstations, databases, routers, firewalls, etc.) present in your network. Assign a value and criticality level to each asset based on its importance to the business and the sensitivity of the data it holds.
--Determine all the possible ways an attacker could gain unauthorized access to your network. This includes external access points like internet-facing servers and services, as well as internal access points like employee workstations and Wi-Fi networks.
--dentify all the services running on each asset. Common services include HTTP (web servers), FTP, SSH, RDP, etc. Make note of the software versions running, as outdated software can be vulnerable.
--List all user accounts and their associated privileges. Understand the principle of least privilege to identify potential issues with excessive permissions.
--Use vulnerability scanning tools to scan your network for known vulnerabilities in the software and services you are running. Pay attention to the critical and high-risk vulnerabilities.
--Analyze your firewall rules and other security devices (e.g., Intrusion Detection/Prevention Systems) configurations. Ensure that they are up-to-date and only allow necessary and secure traffic.
--Evaluate how data is protected both at rest and during transmission. Encryption, secure protocols, and access controls should be in place to protect sensitive data.
--Assess the strength of authentication mechanisms, such as passwords, multi-factor authentication (MFA), and certificate-based authentication.
--Ensure that devices and applications do not have default credentials or configurations, as these are easy targets for attackers.
--Assess the potential impact of social engineering attacks, as they can bypass technical security measures by exploiting human vulnerabilities.
--Verify that your organization has a well-defined incident response plan in place, which includes steps to detect, respond to, and recover from security incidents.
--Consider physical security measures, especially for on-premises assets and data centers, as unauthorized physical access can lead to significant breaches.
--If possible, conduct penetration testing (ethical hacking) to simulate real-world attacks and identify potential weaknesses. Ensure this is done by qualified and authorized individuals or a reputable third-party security firm.
--Create a detailed report that documents all the vulnerabilities and weaknesses you've identified, along with specific recommendations for mitigating them. Include a risk rating to prioritize actions based on severity.
Cybersecurity is an ongoing process. Continuously monitor your network for new vulnerabilities, stay up-to-date with security patches, and periodically conduct new attack surface mappings to improve your overall security posture.
Best regards
6 Replies 6
Hi @kamranshareef
  If you get a guidance for this, it seems to be a PacketTracer project, you will not be able to follow as the PK have limited functions.
what I suggest to you is watch videos like this one I am attaching. Basically the PK have one sniffer device from where you can run tests on the network and that´s it.
https://www.youtube.com/watch?v=h571VfX0S5Y
thank you, will do!
M02@rt37
General guidelines:
Best regards
Really appreciate it, thank you for these guidelines. definitely helpful
ammahend
all great inputs here, my 2 cent, as starter you might also want to ask 5 key questions about the network who, what, where, when and how and then ways to control and trust each.
who - is the users (identity sources ?), what kind of devices they are using (trusted, jail broken, non-compliant ?) when are they accessing network (time) , where they are accessing network from (location) and how they are accessing (Wired, wireless, VPN ... are these following proper security standards ?)
and try to explore how each question can translate to a potential security attack surface for e.g. who (identity can be AD, local user, unique cert to a device etc. and so on) what would be most secure way to identity a user/machine to connect to my network and google vulnerabilities associate with each type and you may come across something like CVE-2023-3128 with AD, and you continue, I think you get the idea, hope this helps a bit.
-hope this helps-
got it, thanks mate!
