How to configure cisco switches using Cisco Prime Infrastructure
nazir.haron
Hi .. could anybody guide me how to configure cisco devices/switches using PI ?
Do and Don't tips/trick
thanks a lot
- nazir
Vinod Arya
Once you add the device to PI, the simplest way to configure those devices using PI is to use the Templates.
The Deploy menu in Cisco Prime Infrastructure allows you to deploy previously configured tasks, profiles, and software immediately or at a future time.
Use configuration templates in Prime Infrastructure to design the set of device configurations that you need to set up the devices in a branch or change the feature configuration for a device from the Device Work Center.
For more details check the following document :
Deploying Templates and Tasks
Configuring Device Features
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
