How to configure RMON traps on Cisco ISR 3845
S. Hasan
I want to configure RMON to monitor tunnel interfaces on Cisco 3845 router.
I tried to search but the configuration which i found is not functional on my routers.
Can anyone help ???
IOS Version 12.4(3g.
Thanks.
hello,
Thanks for your reply.
I had already viewed this document but it is not solving my problem, i have to run rmon on tunnel interface, is there any way out to get rmons traps of tunnel interfaces.
rgds, Raheel
RMON doesn't care about the interface type. RMON allows you to watch a MIB object to see if it crosses a certain threshold. Provided there is such an object for your tunnel interfaces, then the document to which I pointed you should be sufficient to configure your RMON events and alarms. Exactly what do you want to monitor on this tunnel interface? What MIB object?
