how to configure rspan between nexus 5000s and 4506e
Fadi2
Hi all
I was trying to configure a remote span between a cisco nexus 5000 and a catalyst 4506 core switch
the source of the traffic is from a server connected to the 5k and the destination port is on the 4506, I have a remote span vlan between the devices but I can't figure out how to configure them
can someone please help
Francesco Molino
As far as i recall, rspan isn't possible on Nexus 5k. Instead you can implement ERSPAN.
However, there're some limitations for ERSPAN on Catalyst 4500.
Take a look on that document;
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-9-0E/15-25E/configuration/guide/xe-390-configuration/erspan.pdf
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
so this mean I can't configure the normal remote span with the below commands
#monitor session 1 source interface f0/1 (you can choose receive, send, both)
#monitor session 1 destination remote vlan 2
#monitor session 1 source remote vlan 2
#monitor session 1 destination interface f0/2
Honestly, on Nexus 5k, rspan wasn't working/possible.
You can check the Nexus documentation based on your nx-os version to validate.
I've done a quick search and still not possible on this platform
Francesco
