How to deploy a template to an interface with a specific network-policy configured?
We need to change the vlan assigned to a large amount of telephones and we are trying to design a template with that purpose. We are using Cisco Prime Infrastructure v3.3.
Our telephones get the vlan from a network-policy configured on the switchport using lldp-med:
                interface FastEthernet1/0/6
                 switchport mode access
                 network-policy 167
We have been looking for the table from "DB table list" where the network-policy of a switchport appears without success to include a new variable on CLITemplateDbVariablesQuery.properties.
Does anybody know where can we get that information?
Thank you in advance, J.A.
Unfortunately this parameter is not saved into DB, you could use compliance audit policy rules to match the desired configuration and than take a config change action (fix job):
How To Perform a Compliance Audit
iportuga
Hi Juan,
If I understand correctly is your goal change only the network-policy profile number for a bunch of interfaces?
Could you give more details and an example?
Igor
Yes, we need to modify the network-policy on some interfaces with telephones connected on them.
PCs use switchport access vlan and telephones network-policy. Our PC + telephone configuration is:
interface FastEthernet1/0/1
switchport access vlan 4
network-policy 151
speed 100
duplex full
storm-control broadcast level 10.00
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
And we want to modify the network-policy profile number from 151 to 150 in the interfaces where the profile number is different from 150.
We are able to identify the ports with a specific switchport access vlan but not to guess the network-policy configured on an interface.
We can get the ports with a specific access vlan using next query on https://SERVER_PRIME/webacs/dbQueryAction.do:
select u.name from VLANSwitchportSettings u where u.accessVlan != '1' and u.owningEntityId = 'switch_id' and u.accessVlan = 151 order by u.name
Unfortunately, the ports with network-policy 151 configured on them don´t appear.
We have looked for that information on https://SERVER_PRIME/webacs/dbTableListAction.do without success.
Do you know any table with the information of the network-policy configured on an interface?
