how to enable netflow in 6509
andyc2002
Sir
if I wanna enable netflow in one interface of 6509,after I check,it hasn't "ip route-cache flow" command,can you tell me how to do?
Thanks!
On 6500 switches you need to configure netflow globally to collect statistics from traffic that flows through the switch.
Check out the link below for more info.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a2b.html#wp1047637
HTH,
Sundar
