How to enable Netflow on Nexus 7k
I'm configuring the Assurance in Prime Infrasctructure 2.0 and would like to know how to configure NetFlow to export TCP and UDP traffic on Nexus 7k.
In the PI user guide 2.0 document there's no reference for nexus 7000.
Thanks Patricia Oliveira
AFROJ AHMAD
Hi Particia,
check the below link, hope it will help:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_15netflow.html#wp1069829
Thanks-
Afroz
[Do rate the useful post]
*****Ratings Encourage Contributors *****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Vinod Arya
Here is an example netflow configuration.
Basically, you need to use a flow record, flow exporter, and flow monitor.
flow exporter test
  destination 10.1.1.1
  transport udp 50001
  source Vlan1
  version 9
flow monitor Netflow
  record netflow-original
  exporter test
In this case the monitor uses the pre-configured template flow record which is "netflow-original'.  You can see the template for this record by looking at the output from "show flow record".
Below are the Configuration Guide and Command References for Netflow on Nexus.
Configuring NetFlow
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/system_management/configuration/guide/sm_15netflow.html
Command Reference
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/system_management/command/reference/sm_cmd_f.html
Show flow Exporter
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/system_management/command/reference/sm_cmd_show.html#wp1019376
Show Flow Interface
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/system_management/command/reference/sm_cmd_show.html#wp1019505
Show Flow Record
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/system_management/command/reference/sm_cmd_show.html#wp1020037
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thanks so much for the answsers.
Patrícia Oliveira
Glad to help! Please rate useful suggestions/answers.
-Thanks
