How to monitor CPU processes instead of CPU as a whole
joch2joch
We have been using SNMP tools to monitor our router CPU utilization. While it is helpful to see the trend/peaks....we really need to be able to see the exact CPU process that is contributing to the CPU peaks.
Does anyone know how we can achieve this?
Thanks for the wisdom!
Joe
beth-martin
Level 5
Level 5
You can try using the suite of SNMP tools such as UCD's snmpwalk utility.This is available for free
download at http://sourceforge.net/project/showfiles.php?group_id=12694.You could also refer to the webpage which explains how the CPU utilization can be collected using SNMP.
The URL is http://www.cisco.com/warp/public/477/SNMP/collect_cpu_util_snmp.html
ioiioi2000
Thers is a problem with using snmp to monitor CPU's unitilizatioin.
The OID which I use in mrtg is 1.3.6.1.4.1.9.9.109.1.1.1.1.5.1, but the graphic is not as accurate as the result of "show process cpu history".
for example:
show process cpu history at 16:30
100 1225221114111141112141112421212322124112214111131122231111
90
80
70
60
50
40
30
20
10 *
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
data come from prtg which is similer to mrtg:
2005-4-4 16:25 - 16:30 1.000
2005-4-4 16:20 - 16:25 1.000
2005-4-4 16:15 - 16:20 1.000
2005-4-4 16:10 - 16:15 1.000
2005-4-4 16:05 - 16:10 1.000
2005-4-4 16:00 - 16:05 1.000
2005-4-4 15:55 - 16:00 1.000
2005-4-4 15:50 - 15:55 1.000
2005-4-4 15:45 - 15:50 1.000
2005-4-4 15:40 - 15:45 0.900
2005-4-4 15:35 - 15:40 1.000
2005-4-4 15:30 - 15:35 0.900
2005-4-4 15:25 - 15:30 1.000
2005-4-4 15:20 - 15:25 1.000
2005-4-4 15:15 - 15:20 1.000
2005-4-4 15:10 - 15:15 1.000
2005-4-4 15:05 - 15:10 1.000
2005-4-4 15:00 - 15:05 1.000
2005-4-4 14:55 - 15:00 1.000
so, which one I should trust?
joch2joch
Hmm, let me repeat my objective here: I don't want to view the CPU as a whole.
I want to monitor EACH CPU process over a period of time
Does anyone know if this is possible? Are there any Cisco Systems specialist monitoring this thread?
Thanks!
CISCO-PROCESS-MIB is probably what you're looking for - it shows the cpu utilization, by process, for each cpu
Note that there can be multiple CPUs in the box. For example, a cat6500 in native mode shows a switch processor (probably the L2 supervisor card) and a route processor (L3 MSFC)
snmpwalk cat6000 cpmCPUTotalPhysicalIndex
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.1 = INTEGER: 5015
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.2 = INTEGER: 5001
snmpwalk cat6000 entPhysicalDescr |grep CPU
ENTITY-MIB::entPhysicalDescr.5001 = STRING: CPU of Switching Processor
ENTITY-MIB::entPhysicalDescr.5015 = STRING: CPU of Routing Processor
no idea how to figure out which cpu is which on a 7500. The RSP counts as a CPU along with any VIPs but, at least on our 7500s, cpmCPUTotalPhysicalIndex is always zero :-(
snmpwalk c7500 cpmCPUTotalPhysicalIndex
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.1 = INTEGER: 0
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.2 = INTEGER: 0
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.3 = INTEGER: 0
