how to remove devices from LMS 2.6
eliaspaulos
I want to remove all access points from CS and CM they are not on RME. what's the easy way to do that.
Choose Standard, and do not pick a device type.
8 Replies 8
Joe Clarke
Remove them from DCR. Go to Common Services > Device and Credentials > Device Management, and delete them from there. That will remove them from all LMS applications.
thank you so much J. same time how I can added WLSE on LMS.
Same location. Instead of clicking Delete, click Add, and input the details for the WLSE.
thank you so much...no words how much you did help me!!! what management(standard, CNS,auto or
cluster? chose for WLSE. removing those may be helping me my inode/ out of space issue temporarily.once
I have Add WLSE and remove AP's. so now how I should setup AP not to be found again? how I can block AP not to add on DCR. Thanks
Hi jclarke
I have 41 devices that state in the Config Archive, they have failed to collect. I have 679 successfully connected devices. However when I click on the number of devices it brings a new window open showing 105 devices. I get the error
"SSH: Failed to establish SSH connection to xx.xx.xx.xx - Cause: Authentication failed on device 3 times. Failed to fetch config using RCP.Verify RCP is enabled or not. PRIMARY-STARTUP config Fetch Operation failed for TFTP. TELNET: Failed to establish TELNET connection to xx.xx.xx.xx - Cause: Authentication failed on device 3 times.
I have tried to remove them from Common Services, DFM and RME but they are not defined there. Is there a command line util I can use to delete items that are no longer on the network but installed in CiscoWorks. I am running LMS 3.0.1
No. In order to clean up stale config archive failure entries, you need to run a database query. You will need to contact TAC to help you with this.
