How to restore CISCO 4331 to factory settings
bhumika1224
Wanted to know if the CISCO 4331 has RESET button on it ?
Also I have remote console access by reverse telnet through another CISCO router. In case I go by Break  process will reverse telnet work ? I have standard keyboard, for Break can I use CTRL + BREAK ?
Leo Laohoo
I don't think there is a reset button.
