HSRP does not work somehow
Hi all!
I am trying to configure a collapsed layer network architecture. I configured HSRP and L3 switches sees each other with no problem (sh standby br is OK) but when I configure a PC in VLAN10 and give default gateway as the HSRP virtual IP to it, there is no connection. But when I configure the PC's default gateway as the VLAN10 IP of the CLSwitch1, pings are succesfull. Access switches are L3 switches with "no ip routing" by the way. Let me share the configs. Thanks in advance!
19 Replies 19
Oh no it did not work. I wanted to cross check this topology on Packet Tracer too. I believe there is some kind of a bug or configuration issue with L3 switches on GNS3. Same thing works on PT but not on GNS3.
I see. Not really sure how to help here as it seems to be an issue on GNS3 rather than your config itself. Did you check if there is any newer version of GNS3 that you can update to? also have you ever considered buying Cisco CML?
Cisco Modeling Labs - Cisco
The only update awaiting is Vmware Player.
I think I am going to buy used physical equipment for cheaper prices.
Have you ever considered Cisco CML?
NO need use eve-ng I use it and it more stable than GNS3
MHM
