I need help configuring a connection with asdm 5.2 for asa
daveyboy1972
Hi All
I am very much a novice with asdm 5.2 for asa and I urgently need to configure a connection but don’t know how to. I have 2 domains at work and someone is trying to connect their sql client from their pc in one domain to the sql server in the other domain (DMZ).
When he tries to connect he gets the error
Cant connect to MySql Server at "IP Address" (10060)
He is trying to connect on port 3306. Could anyone please give me any tips on how i can resolve this quickly? I know i am
trying a shortcut on this one but I recently started a new job and thrown in the deep end here and need to learn this asdm 5.2 for asa product from scratch with nothing more than the manual that come with the cd .
My Cisco knowledge is from 2001 when i did half of a ccna course.
Any help would be greatly appreciated
ngoldwat
Level 4
Level 4
I'm not a security specialist but here is how I had it set up at home:
Essentially a NAT and a rule forwarding the port are needed. In this particular case I had an Oracle server running and a person requested remote access. So, for example, the source address was his external IP and the destination was the Oracle's external IP. For the NAT the source was the internal IP of the Oracle server and the interface was Outside.
Hope this points you in the right direction.
Thank you for the reply ngoldwat. Very helpful. Much apprechiated
