I need help in configuring the network (BGP & 2 ISP)
florinmarian
Greetings, friends!
After noticing that in this community there really are people willing to help and teach you, I come again with some problems to which I hope I will find an answer (either directly or indirectly).
Let me describe my resources:
- The Cisco WS-4948E switch
- ASN AS57XXX
- Subnets 188.241.XXX.0/24, 188.241.YYY.0/24 and 2a0e:8f02:XXXX::/48 respectively
- ISP A, which does not support BGP session, having the IP address 192.168.1.XXX configured on the switch, unable to give up the router provided by the ISP
- ISP B which supports BGP session, having the IP address 10.192.63.XXX configured on the switch, without having any public IP address or any intermediate device between the switch and the ISP
What I want:
1. How should the network be divided into vlans knowing that I connect the ports GigabitEthernet1/1 and GigabitEthernet1/2 to the router of the first ISP, GigabitEthernet1/3 to the 2nd ISP and I want to allow the other ports of the switch to be considered consumers that can only have IP addresses from the 3 subnets listed above (so the Switch should serve as a gateway with the IPs 188.241.XXX.1, 188.241.YYY.1, 2a0e :8f02:XXXX::1)?
2. In what way can the 2 ISPs be used knowing that one allows BGP session, the other does not but the one that does not allow BGP session still does not filter the IPs?
Configuration examples would be welcome because it's the first time I'm interacting with a Cisco switch.
Thank you!
23 Replies 23
I write some note and two command you can use to check the connectivity
telnet and debug
Hello!
In the end I managed to establish the BGP connection via IPv6 with RCS RDS and announce the /48 route through it, but the problem I am facing now is that from the client using the IP address 2a0e:8f02:XXXX::2 with the gateway -ul 2a0e:8f02:XXXX::1 I get timeout when I try to send pings to the internet.
That client is connected to GigabitEthernet1/48.
Thank you!
Commands used after factory reset:
vlan 200
name RCS&RDS
vlan 300
name Clients
interface GigabitEthernet1/3
description Connection to RCS&RDS Router
switchport mode access
switchport access vlan 200
no shutdown
interface range GigabitEthernet1/4 - 48
description Consumer Ports
switchport access vlan 300
interface range TenGigabitEthernet1/49 - 52
interface vlan 200
description Conexiune RCSRDS
ip address 10.XXX.63.19 255.255.255.248
ipv6 address 2a02:2f08:XXXX::2/126
no shutdown
interface vlan 300
description Conexiune Servere
no shutdown
ipv6 address 2a0e:8f02:XXXX::1/64
ipv6 unicast-routing
router bgp 57403
bgp router-id 10.XXX.63.19
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 2a02:2f08:XXXX::1 remote-as 8708
address-family ipv6
neighbor 2a02:2f08:XXXX::1 activate
network 2a0e:8f02:XXXX::/48
exit-address-family
end
Good to know that' so you now receive both ipv6 and ipv4 from isp'
The access to internet need you receive defualt route from ISP.
Those are the routes I received and it's strange because I requested /48 and I see just /64 but anyway, even with /64 my IP is not accessible from other networks.
*May 26 23:38:02.635: BGP IPv6: Walker update route ::/127
*May 26 23:38:02.635: BGP IPv6: Walker update route 2A02:2F08:FFF::2/128
*May 26 23:38:02.635: BGP IPv6: Walker update route 2A02:2F08:FFF::/126
*May 26 23:38:02.635: BGP IPv6: Walker update route 2A0E:8F02:F04F::1/128
*May 26 23:38:02.635: BGP IPv6: Walker update route 2A0E:8F02:F04F::/64
*May 26 23:38:02.635: BGP IPv6: Walker update route FE80::/10
*May 26 23:38:02.635: BGP IPv6: Walker update route FF00::/8
are there any FW in-between ?
No, just default ACLs which cannot be deleted. The switch is directly connected to ISP's ONT.
This is actually full configuration of the switch:
Switch#show running-config
Building configuration...
Current configuration : 7807 bytes
! Last configuration change at 00:03:01 UTC Sat May 27 2023
version 15.2
no service pad
service compress-config
hostname Switch
boot-start-marker
boot system flash bootflash:cat4500e-entservicesk9-mz.152-4.E10a.bin
boot-end-marker
vrf definition mgmtVrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 100
 name Orange
vlan 200
 name RCS&RDS
vlan 300
 name Clients
interface FastEthernet1
 vrf forwarding mgmtVrf
 no ip address
 speed auto
 duplex auto
interface GigabitEthernet1/1
 description Connection to Orange Router
 switchport access vlan 100
interface GigabitEthernet1/2
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/12
interface GigabitEthernet1/13
interface GigabitEthernet1/14
interface GigabitEthernet1/15
interface GigabitEthernet1/16
interface GigabitEthernet1/17
interface GigabitEthernet1/18
interface GigabitEthernet1/19
interface GigabitEthernet1/20
interface GigabitEthernet1/21
interface GigabitEthernet1/22
interface GigabitEthernet1/23
interface GigabitEthernet1/24
interface GigabitEthernet1/25
interface GigabitEthernet1/26
interface GigabitEthernet1/27
interface GigabitEthernet1/28
interface GigabitEthernet1/29
interface GigabitEthernet1/30
interface GigabitEthernet1/31
interface GigabitEthernet1/32
interface GigabitEthernet1/33
interface GigabitEthernet1/34
interface GigabitEthernet1/35
interface GigabitEthernet1/36
interface GigabitEthernet1/37
interface GigabitEthernet1/38
interface GigabitEthernet1/39
interface GigabitEthernet1/40
interface GigabitEthernet1/41
interface GigabitEthernet1/42
interface GigabitEthernet1/43
interface GigabitEthernet1/44
interface GigabitEthernet1/45
interface GigabitEthernet1/46
interface GigabitEthernet1/47
interface GigabitEthernet1/48
interface TenGigabitEthernet1/49
interface TenGigabitEthernet1/50
interface TenGigabitEthernet1/51
interface TenGigabitEthernet1/52
interface Vlan1
 no ip address
interface Vlan100
 description Conexiune Orange
 ip address 192.168.1.2 255.255.255.0
interface Vlan200
 ip address 10.192.63.19 255.255.255.248
 ipv6 address 2A02:2F08:FFF::2/126
interface Vlan300
 no ip address
 ipv6 address 2A0E:8F02:F04F::1/64
router bgp 57403
 bgp router-id 10.192.63.19
 no bgp fast-external-fallover
 bgp graceful-restart restart-time 120
 bgp graceful-restart stalepath-time 360
 bgp maxas-limit 50
 neighbor 2A02:2F08:FFF::1 remote-as 8708
 address-family ipv4
  no neighbor 2A02:2F08:FFF::1 activate
 exit-address-family
 address-family ipv6
  network 2A0E:8F02:F04F::/48
  neighbor 2A02:2F08:FFF::1 soft-reconfiguration inbound
  neighbor 2A02:2F08:FFF::1 maximum-prefix 250000
 exit-address-family
no ip http server
no ip http secure-server
ip forward-protocol nd
line con 0
 stopbits 1
line vty 0 4
 login
end
you must connect ISP, it not BGP issue the IP (IPv4 or IPv6) is not reachable.
It seems to be also a vlan issue because I found this:
Switch#show ipv6 route
IPv6 Routing Table - default - 6 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
       B - BGP, R - RIP, H - NHRP, I1 - ISIS L1
       I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary, D - EIGRP
       EX - EIGRP external, ND - ND Default, NDp - ND Prefix, DCE - Destination
       NDr - Redirect, O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1
       OE2 - OSPF ext 2, ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
       a - Application
B   ::/0 [20/0]
     via FE80::D161, Vlan200
C   2A02:2F08:FFF::/126 [0/0]
     via Vlan200, directly connected
L   2A02:2F08:FFF::2/128 [0/0]
     via Vlan200, receive
C   2A0E:8F02:F04F::/64 [0/0]
     via Vlan300, directly connected
L   2A0E:8F02:F04F::1/128 [0/0]
     via Vlan300, receive
L   FF00::/8 [0/0]
     via Null0, receive
Switch#ping fe80::d161
Output Interface: vlan200
Sending 5, 100-byte ICMP Echos to FE80::D161, timeout is 2 seconds:
Packet sent with a source address of FE80::C671:FEFF:FE8C:7D3F%Vlan200
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/12/12 ms
Output Interface: vlan300
Packet sent with a source address of FE80::C671:FEFF:FE8C:7D3F%Vlan300
Success rate is 0 percent (0/5)
Switch#ping ipv6 ipv6.google.com
Sending 5, 100-byte ICMP Echos to 2A00:1450:4001:806::200E, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/48/52 ms
Switch#
VLAN200 is success
VLAN300 is failed ?
show ip inter brief <<- check if SVI of VLAN is UP
show vlan <<- check if VLAN is add to VLAN DB
NOTE:- if you dont advertise the IP of VLAN's to ISP then you Need NAT overload to interface connect your SW to ISP
