IFindex value for the interface in CAT 4K switch
Zubair Ansari
Hello Everyone,
Could someone please help me in getting IF index value for the interface in CAT 4K switch?
Thank you.
Mark Elsen
 - "the interface" is probably a bit narrow since your switch has many interfaces : snmpwalking the ifmib will denote you the names and the values.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
julian.bendix
Level 7
Level 7
Hi!
First of all - ifIndex of the intefaces can change during a reboot of the Switch.
You can configure "#snmp-server ifindex persist" to solve this problem.
Then, the following command to check the MIBs for interfaces should work on Cat4k:
#show snmp mib ifmib ifindex
Hope that helps,
Julian
