Import device
ciscoforum
Level 7
Level 7
How can I export all the routers/switches from one ciscoworks then import to the other server? version 2.51. Thanks
David Stanford
you can go to Common Services -- Device Credentials -- Device Management you can select the option to Export from there.
Then on the other server under this same menu you can select Bulk Import
Thanks very much
