Importing Devices into Ciscoworks via Seedfile
aw_wongala
How can one import a bunch of devices into new ciscoworks version via seedfile? It is different to the older versions as the inventory dump includes sysOID attributes etc that were not included before. Help!
Just leave those fields blank. RME will query the device for the OID.
6 Replies 6
David Stanford
You would need to get the format of the new seed file and use that. If you attempt to use the old seedfile format it will fail.
You could get a sample csv file from LMS 2.5 by manually adding a device and exporting it. Then use something like excel to copy and paste fields from the old one to the new one.
Thanks i tried that but there are new fields like sysOID which seem to be different for each device... thats what i need to workaround. Appreciate the help!
thanks i will give that a whirl and post my findings .. sounds like what i want to hear so lets see if it works! thanks henniae
If you are looking for the sysObjectID's you can find the here:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_4_x/4_0_3/sdt/rme403.htm
Thanks guys its worked and im over the moon!! Thanks for all your help!
