Incorrect SSH
russnash
I have a 2600 router that has a "no configuration achieved " message. When I check credentials I get incorrect SSH? Do I need to delete and add the device?
Richard Burts
Russ
Can you confirm that the 2600 does have the RSA keys generated and that SSH is active? If SSH is active is it possible that there is a mismatch in version (version 1 vs version 2)?
Rick
Rick
looks like a version mismatch. device is using 1.0, how can I change cisco works to match cersions?
