Integration between CTM and HP Overview
ahmadfarkhan
Hi Expert. I need information regarding integration between CTM and HPOV NMS. Could CTM integrated to HPOV ?.
mosho
Yes, CTM can integrate with HPOV with SNMP.
First you will have to get the ONS15xxx mibs from Cisco.com or from the ONS15xxx cd, load and compile it in HPOV. Follow the adding ONS15xxx MIBS steps. You will also have to modify the HPOV config file so that it will start display ONS15xxx mibs interpretation.
--Moses
thanks for the info.
