10-02-2007 10:01 PM
When I run the inventory report I have the following fields:
Updated At System - Name Domain - Name Description - Serial Number - Contact - Location ...
How can I add the "serial number"
I tried editing credentials but "SN" it's not the same as serial number.
Solved! Go to Solution.
10-08-2007 01:37 PM
For the chassis serial numbers you either enter then manually using Change Device Attributes or when you add a device manually to the RME database. If you want CampusManager to automatically discover the serial number you need to use the command "snmp-server chassis-id (serial number)" The problem with this is that some devices will not take this command and you have to enter the number manually.
10-08-2007 01:37 PM
