IOS upgrade through RME
gopakumarmk
Hi, I am trying to upgrade our 3550CAT switch through RME, showing error "check flash0 exist". It has only one option to select in RME->distribute by devices->storage options->flash0, but Switch IOS dir is named as flash:. How can i change the target directory from flash0 to Flash.
Running Cisco LMS 2.5 & RME V.4.0.1
PAUL TRIVINO
Level 3
Level 3
That *sounds* like an RME bug - I think it just has to know what filesystem(s) exist on a device, otherwise you'll get some error like that.
Paul
Thank you paul.
The running IOS version of 3550 is 12.1(13)EA1a. The strange thing is when i tried to upgrade Cat3560 IOS it is showing flash1 and error is "check flash1 exist". 3560 IOS version is 12.1(19)EA1d.
Please advice.
I think you are running into bugs here
If you have the right to download patches from cisco go here
http://www.cisco.com/cgi-bin/tablebuild.pl/lms25
If not get the person from who you bought ciscoworks to download it for you
On this page you find reference to other more recent updates you can download
http://www.cisco.com/kobayashi/sw-center/cw2000/lan-planner.shtml
Cheers,
Michel
David Stanford
Looks like bug CSCsb30408 which is resolved in RME 4.0.2
