05-18-2017 11:14 PM
Hi Guys,
I'm having a cisco 3560 switch in my office and DHCP servers are been configured on it and PC are connected towards that. I need Ip accounting and destination address Ip details to be monitored in case of excess bandwidth. Could you please suggest what should be configured inside the switch to monitor traffics?
Solved! Go to Solution.
05-22-2017 12:11 AM
not sure what you mean by grouping them but here is how you deploy it , this is a working template off a switch of mine , there is no other way to deploy accounting though its legacy its netflow you use now in ios , if its not there its been removed
apply this under any layer 3 ip interface you want to collect data off , set the destination collector and souorce interface usually a loopback, you can set the transport protocol if you wish depending again on your collector
under interface
ip flow monitor netflowtest input
ip flow monitor netflowtest output
in global config mode
flow record FLOW-RECORD
description record to monitor network traffic
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match interface output
collect routing source as
collect routing destination as
collect routing next-hop address ipv4
collect transport tcp flags
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter NetQos
description export Netflow traffic to HQ
destination x.x.x.x
source xxxxxxxx
template data timeout 300
option interface-table timeout 1000
option exporter-stats timeout 1000
description Used for ipv4 traffic analysis (Mapped To FLOW-RECORD)
record FLOW-RECORD
exporter NetQos
statistics packet protocol
to see of the router is collecting flows ....show flow exporter statistics
05-19-2017 03:48 AM
if its still supported on your ios version as its a deprecated command now legacy , its been removed from ios-xe , still should be on the older 3560 switches though running old ios but in v15 it may not be there for you if your running that
netflow is what you should use now for data collection , not ip accounting and it would be verdsion 5 on 3560
if you can configure ip accounting all you do is set that on each interface you wish to monitor ...ip accounting
see doc
http://www.ciscopress.com/articles/article.asp?p=764234
05-21-2017 10:59 PM
Hi Mark,
Ip accounting cannoit be enabled in the interface of the switch, we can user netflow but in IOX-XE netflow can be enabled by grouping them only. But i didnt get clear idea of creating the netflow group and adding them. Could you assist me on enabling netflow and other way for Enabling IP accounting.
Nimil
05-22-2017 12:11 AM
under interface
match ipv4 tos
match ipv4 protocol
destination x.x.x.x
source xxxxxxxx
record FLOW-RECORD
exporter NetQos
05-22-2017 12:18 AM
thanks for the config's. i'll try it to my switches and check whether it's working or not.
